self locking nut (suspension)
Old Aug 13, 2002 | 02:13 PM
quikrpm'z's Avatar
Default self locking nut (suspension)
where can i find this, home depot doesnt have the right one and acura doesnt have it in stock. This is the self locking nut that comes off the flange bolt. The manual recommeds replacing it.
also do i just use axle grease for the bushing on the lca, the manual says grease then to the side of it says silicone grease?
Old Aug 13, 2002 | 04:27 PM
poison's Avatar
Default Re: self locking nut (EVIL Teken)
You need to make your purchase at the dealer for that nut... Silicone grease is the preferred choice as it is temperature stable in a wide variety of climates...
EVIL Teken...
Correct, or try finding it at http://www.hondaautomotiveparts.com
or
http://www.acuraautomotiveparts.net
Old Aug 13, 2002 | 09:17 PM
VTECorona's Avatar
Default Re: self locking nut (poison)
I wonder why they recommend replacing it? I'm doing my suspension this weekend and now that has me thinking if I should get new ones. Are you talking about the nut that goes onto the long bolt that connects the damper fork to the control arm?
Old Aug 13, 2002 | 09:29 PM
Brian_92GSR's Avatar
New User
Default Re: self locking nut (97RedTegGSR)
I'm not sure - do most people replace those as directed? I've taken apart the entire suspension so many times I'm sure I would have spent a fortune on replacing everything so many times.
Old Aug 13, 2002 | 10:47 PM
Flamenco-T's Avatar
I have taken my suspension off many many many times, and never have to replace the nuts...unless they're hard to thread in, you do not need to repalce it...
if they're tque right, you'll be okay...
Old Aug 13, 2002 | 10:53 PM
quikrpm'z's Avatar
I wonder why they recommend replacing it? Are you talking about the nut that goes onto the long bolt that connects the damper fork to the control arm?
yes that one. Heres the part number 90215-SB0-003. The only reason why i see they recommend replacing it is because its a locking nut.
Teken, i just bought all purpose grease. That wont work? the stores i went had never heard of silicone grease, nor did the honda parts person. which was a very cute girl.
Old Aug 16, 2002 | 11:14 AM
93CivicSI's Avatar
Default Re: self locking nut (quikrpm'z)
Buy the correct hardware or you will be hating yourself later.
AMS_
Dec 12, 2013 07:24 AM
neopheus
Mar 18, 2005 10:53 PM
munscher
Jun 13, 2003 05:45 PM
CXHatchback
Jun 5, 2003 09:22 PM
