turbo downpipe help
Old Mar 24, 2009 | 05:53 PM
dcintegra88's Avatar
Default turbo downpipe help
what type of downpipe would i use on this turbo??Name:  IMG_0278.jpg
Old Mar 24, 2009 | 05:56 PM
moochie972's Avatar
Default Re: turbo downpipe help
It looks like a 4-bolt to me.
Old Mar 24, 2009 | 05:59 PM
a friend of mine told me it looked like it needed a piece for the downpipe. but idk much about turbos.
mikeymcm's Avatar
v band
Old Mar 24, 2009 | 06:01 PM
so would i need to get a flange or something to connect it?
Old Mar 24, 2009 | 08:56 PM
i meant do i need a flange to connect the downpipe to the turbo. or just the downpipe and a clamp?
Old Mar 24, 2009 | 10:29 PM
omgwtfbbq's Avatar
it looks like it used a vband flange, but doesnt look like thereis any room to clamp it
Old Mar 24, 2009 | 11:23 PM
any suggestions on what i can do.
Old Mar 25, 2009 | 04:24 AM
ExVtec's Avatar
http://www.atpturbo.com/Merchant2/me...gory_Code=GTBB
Weld a proper vband on it.
Old Mar 25, 2009 | 11:57 AM
Ok thanks guys for the help!
Old Mar 25, 2009 | 04:00 PM
Tyson09's Avatar
make sure you take the housing off before welding it haha
Old Mar 25, 2009 | 04:05 PM
wade's Avatar
what the hellll, i never seen anything like that. IF that is a Vband, it is DEF different.
Old Mar 25, 2009 | 04:47 PM
TheShodan's Avatar
Moderator
No. you're just not used to seeing the turbine housing before the v-band is welded. ONly about 10 percent of the v-band turbine housings that are ever made are actually cast as one piece. The rest are welded. That is what it looks like before it is welded on.
Old Mar 25, 2009 | 11:36 PM
ok ill make sure to take the housing off. thanks for the help!
Old Mar 26, 2009 | 01:28 AM
project dc2's Avatar
the part posted as the vband is the wrong one
HERE IS THE ACTUAL VBAND YOU NEED THAT WILL FIT PERFECT
http://www.atpturbo.com/Merchant2/me..._Code=ATP-FLS3
3" steel weld flange, VBand. Weld directly to T04 turbine housing with cast in groove to convert complete turbine discharge to standard 3" V-Band
Old Mar 26, 2009 | 12:59 PM
so just weld that flange on then it should be good to clamp up to the downpipe?
Old Mar 26, 2009 | 02:12 PM
SD_Lurker's Avatar
HT White Ops
You got it bubba. Will fit like a glove there after!
Old Mar 27, 2009 | 01:34 PM
haha cool!
blw23
Mar 21, 2013 06:30 PM
hastingsr
Mar 17, 2009 07:46 PM
huepowered
Welding / Fabrication
Jun 8, 2006 04:22 AM
Bailhatch
Aug 7, 2003 07:35 PM
