Fuel line advice
Old Mar 21, 2009 | 01:35 PM
disordinate's Avatar
Icon6 Fuel line advice
What's up,
I wanted to get some advice/opinions on this. I'v posted this type of stuff on other forums but not really getting much help.
I'm Runnin new fuel lines in my hatch. Motors un-boosted for now, running an intake pump.
Eventually will be running an inline pump aswell as an intake pump and pushing high boost(when i can finally get all the parts).
I'm gona run -8AN(1/2") lines now and then when I boost it upgrade the injectors, and add the inline pump.
You guys think I should use stainless steel braided line from the pump to the engine bay, Or should I get hardline and bend my own lines and flare fittings onto em from the tank to the engine bay?
Iv been playin with different set-ups for awhile and can't seem to pick or get set on one specific set-up.
I also have another question, I know with the power i'm aiming for I need to run a -8AN feed. would it have any negative effect If I upgraded My return line to -8AN aswell?
Old Mar 21, 2009 | 02:49 PM
red02s2k's Avatar
Default Re: Fuel line advice
It doesn't matter if you are running a steel braided line or hardin lines as long as it doesn't leak. If you ask me whatever gets the job done is good to me. When you do the hardin line just stop it a couple of feet before the fuel rail and run the braided line for the motor flex and the same on the return. And I am running -10 feed and -8 return so I think you would be more than fine with a -8 feed and return.
Old Mar 22, 2009 | 10:07 AM
thank you. definitly the most solid help iv gotten on this topic so far.
I was gona go steel braided the whole way but i heard nhra rules consider steel braided a soft line and not acceptable for the whole fuel system. I'm not gona run nhra, but if they don't accept it, it made me doubt using it, specially with the price of steel braided per foot. ya know?
you know a good place to get hard line that will hold up to the pressure of fuel injection. most the lines i find either don't say what they'r rated to handle, or are only usable with carbs and handle like 25psi.
and is thier any special way to cut steel braided with out damaging it? because id just be ordering a few feet of it and cutting it to what i need
Old Mar 24, 2009 | 07:47 AM
bumppp
Old Mar 24, 2009 | 08:17 AM
TurboChurch's Avatar
stainless steel hard line,can be found at jegs/summit/on here by at least one of the sponsors, but its a pain to double flare unless you have done it a few times and know to deburr it and lube it before flaring it. Use the correct flaring tool for AN fittings. If you dont know what to do or how to do it, a machine shop should have the tools and be able to flare it for cheap.
Use masking tape for the braided line, wrap a piece around it where you want to cut it. use a hack saw with alot of teeth per inch or find yourself a cutoff wheel and airtool to just slice cleanly through it. Wear gloves, the braid has a tendency to make you bleed.
Old Mar 24, 2009 | 11:27 AM
frenzyh22's Avatar
I've heard of in-tank pumps, but what are intake pumps?
Old Mar 24, 2009 | 03:48 PM
kte324's Avatar
I believe he meant in-tank.
Old Mar 24, 2009 | 04:02 PM
srmofo's Avatar
with an -8 feed, the stock return is more than enough
Old Mar 27, 2009 | 01:33 PM
thank you, great info. guess i'm gona bite the bullet and shell out the money for the stainless line, seems the easiest to do. and is definitly the easiest to find.
Old Mar 27, 2009 | 01:35 PM
Yea, I know. But the car doesnt have any lines in it for fuel, an i don't wanna drop the subframe and all thats involved with that to install one line you know? rather route my own
Old Mar 27, 2009 | 01:52 PM
EVLTEK's Avatar
the stock fuel lines are good for at least 500HP....the easiest way would be to source some OEM lines i would have thought.
Old Mar 27, 2009 | 02:57 PM
Blown90hatcH's Avatar
Earls braided hoses will pass tech and are easy to install with no special tools. -8 return will be fine too as others have stated.
B_Swapped93
May 15, 2017 03:33 PM
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
noluckracing
Jun 26, 2009 02:56 PM
dmotoguy
Mar 2, 2008 10:27 AM
paulzy
Oct 22, 2002 03:35 PM
