Piston-wall clearance v. Ring wear
Old Mar 24, 2009 | 03:57 PM
vinuneuro's Avatar
Default Piston-wall clearance v. Ring wear
Is there any such relationship? Ie. will a tighter p-w clearance yield better ring wear?
How exactly do the oil control rings wear?
Stock motor.
Old Mar 24, 2009 | 04:07 PM
lsvtecwill's Avatar
Default Re: Piston-wall clearance v. Ring wear
What kind of car(sleeves/pistons) are we talking about or is a theoretical question? i.e. forged, cast, or the fiber prelude crap?
Old Mar 24, 2009 | 04:14 PM
4g hatch's Avatar
ive read several articles on honing,rings,etc... from what i gather the type of hone and crosshatch pattern affects wear more than anything.also using the wrong kind of ring for your application. most japan rings i think are nitrate coated which are a great ring.p2w shoulnt affect ring wear much,unless its way to loose and the pistons rock in the bore causeing pre-mature wear.
Old Mar 24, 2009 | 04:19 PM
DonF's Avatar
.001 in wall wear increases ring gap by . 003416 and vise versa. It's just math.
Old Mar 24, 2009 | 04:24 PM
vinuneuro's Avatar
How do the oil control rings wear? Fatigue?
What does the end-gap in these rings affect? Ie. Do they loose tension when the end-gap is out of spec?
Old Mar 24, 2009 | 04:26 PM
4g hatch's Avatar
since don is paying attention,and im curious,will ring gaps affect wear one way or the other. as long as they are not extreme either way. i havent found anything on that yet.
Old Mar 30, 2009 | 01:25 PM
Rocket's Avatar
You have a range. +.001 is not going to hurt.
Ring wear is more adversely affected by cylinder surface finish, cylinder out-of-roundness, and not properly washing out the honing grit.
Old Mar 30, 2009 | 01:30 PM
Dark_Teg's Avatar
I would think the circumferential ring tension would remain the same regardless of ring gap.
Old Mar 30, 2009 | 01:43 PM
vinuneuro's Avatar
Is it then fair to say that a tighter pw clearance will maintain cylinder circularity longer and thus control ring wear better?
Old Mar 30, 2009 | 01:53 PM
mar778c's Avatar
Community Builder
Community Influencer
No, too tight and you can not develop a proper oil wedge.
Just like Don/MOTU, stated +0.001 is good. Wear is more of a function of the two surfaces ie hardness, lubricity, etc. and the duty they will see.
If you are concerned about wear for a FRM sleeve just replace them ductile iron and go with the nitrided rings. The FRM is a very hard surface and it will wear rings faster than ductile iron.
b20vtech
Apr 29, 2007 06:45 AM
Aeka GSR
Sep 28, 2003 11:15 AM
non-VTEC
Oct 26, 2002 08:15 AM
Islander
Oct 11, 2002 02:45 AM
CovertFI
Jun 6, 2002 02:00 PM
