Gear doesnt go in all the way
Old Mar 23, 2009 | 09:56 PM
John 07's Avatar
Default Gear doesnt go in all the way
So I recently noticed this but sometimes The gear doesnt go all the way in when in reverse and 1st gear. Feels like it gets stuck half way. But then I just wiggle the stick shift around a little in neutral and it goes right back into gear. Has anyone ever have this issue?? This only happens sometimes during the week. all other geears are like butter
Old Mar 24, 2009 | 03:22 PM
lsvtecwill's Avatar
Default Re: Gear doesnt go in all the way
Do you have a short shifter? I had this problem with one, with the stock one it was great shifting. Also does it only do this when you are at a dead stop?
Old Mar 24, 2009 | 03:26 PM
Pr-Type-R's Avatar
i have the same issue in the same gears..never really thought of it as a problem though
Old Mar 24, 2009 | 04:54 PM
John 07's Avatar
mines stock with the skunk ****
Old Mar 24, 2009 | 11:56 PM
CW-ITR's Avatar
I't normal. I really baby my shifting and it has been that way ever since I own the caR. if you have to ask, it only has 38K miles.
Old Mar 25, 2009 | 04:08 AM
Dave-ROR's Avatar
Common issue.
Old Mar 25, 2009 | 06:45 AM
Devon M's Avatar
Same here, I just release the clutch and try again.
Old Mar 25, 2009 | 08:13 AM
Kike_Si's Avatar
I'd say that the slave cylinder is going bad, but since most say its a common problem then I dont know. I dont own an R.
Old Mar 25, 2009 | 09:27 AM
Dave-ROR's Avatar
Nah, hydraulics are fine. It's a common issue with the GS-R and ITR trans. Just don't force it, I usually let the clutch out a little and it'll sldie in.
Or rebuild the trans, that'll fix it for awhile.
Old Mar 26, 2009 | 09:38 AM
imroadk1ll's Avatar
i own a gsr and i usually just put it back to neutral and go side to side then go back to first and its all good. does neone else have a hard time getting onto reverse too?
Old Mar 26, 2009 | 12:18 PM
Dave-ROR's Avatar
This topic was about 1st gear and reverse......
Old Mar 26, 2009 | 01:46 PM
HaZed1's Avatar
mine is like that with reverse. I just put it back into 1st or 2nd and then reverse and itll go in.
To my understanding, isnt reverse the only gear without synchos? I could be wrong but that would explain the common problem with it going in.
shorty10388
Sep 17, 2005 12:49 PM
Bond
Jan 31, 2005 07:14 PM
TypeRTexan
Apr 13, 2004 11:30 AM
unKnown
May 24, 2003 10:55 AM
b20civic
Sep 8, 2002 11:33 PM
