b7 to z6 swap, MAP sensor/wiring questions
Old Mar 23, 2009 | 08:34 PM
RedRevolver's Avatar
Default b7 to z6 swap, MAP sensor/wiring questions
ok, so i am swapping a z6 into my del sol, from a b7. the engine I got had the engine wiring harness connected, so I have that, and for the ECU i bought a conversion kit and basemap from Xenocron. Pretty much I have two questions.
1. where the engine harness plugs into the harness that goes through the firewall, specifically the 14 wire clip on the left side of the engine bay, the wire colors don't match up, so did the z6 just use different colors for the same things or what? can I just plug it right in and not worry about it? (minus the vtec wiring of course)
2. The MAP sensors, on the b7, the MAP sensor is mounted into the engine bay with a hose going to the intake, and it is wired into the harness that goes through the firewall, but on the z6, the MAP sensor is wired into the engine harness, so I have two MAP sensors wired in two different places, and don't know what to do with them. should I just use the one on the z6 and just ignore the other one mounted in my engine bay?
hopefully thats enough information for ya
Old Mar 24, 2009 | 03:38 AM
94EG8's Avatar
Seagull Management
Default Re: b7 to z6 swap, MAP sensor/wiring questions
The colors don't all match up going from one side of the plug to the other. vtec solenoid wire for example is orange/white on one side of the plug and green/yellow on the other. Don't worry about it.
Use the throttlebody mounted Z6 map sensor, but use the connector that was originally plugged into the firewall mounted map sensor (the connector in the Z6 harness isn't connected to anything)
Old Mar 24, 2009 | 09:03 AM
interesting on the MAP sensors, thanks!
thez6kid
Engine Management and Tuning
May 13, 2012 04:46 PM
mr.ed605
Mar 8, 2009 12:33 PM
egmatt93
20
Mar 7, 2008 07:00 AM
raleylund
Oct 18, 2007 12:29 PM
seanclark
Feb 13, 2006 12:25 AM
