Question on Bolts
Old Mar 23, 2009 | 04:59 AM
adventofmusik's Avatar
New User
Default Question on Bolts
Well i was wondering if anyone had a link to either a site or a pdf that can tell me what bolts i need for my engine mounts and trans bolts for my b series swap.
Old Mar 23, 2009 | 05:04 AM
hybridmath's Avatar
Default Re: Question on Bolts
are you looking to buy them if so i got 2 buckets full of honda bolts will sell cheap give me a call 860-883-9374 or email me at hybridmath@aol.com
Old Mar 23, 2009 | 05:42 AM
New User
no more so trying to find the sizes so i can pick some up from a local dealer
Old Mar 23, 2009 | 05:55 AM
cpl rampage's Avatar
Well i don't know what car you have, so i assumed it was a 92-95 civic, in that case, the engine motor mount bolt is 90182-SR3-000 and the transmission mount bolt is 90183-SR3-000. Also if you are looking for the rear torque mount bolt, it is 90165-SM4-020. An the left and right torque mounts use studs, so i assume you don't need those.
Old Mar 23, 2009 | 11:55 AM
rolldog's Avatar
Am looking for tranny bolts that to motor and clutch disc bolts.
Old Mar 23, 2009 | 01:26 PM
Try not to jack peoples thread, but if you want to know, you need to give what car/engine, and more specifically what bolts u want. do u want the tranny to engine bolts, the flywheel to engine bolts or the clutch to flywheel bolts?
Old Mar 23, 2009 | 01:31 PM
rolldog's Avatar
no am jacking anyones thread just a question so dont get so uptight.
Old Mar 23, 2009 | 03:22 PM
thats the thing, his question on motor mount bolts hasnt been compleley answered. i would be happy to tell you what part numbers you need if you would provide me with the information required above. Ill even answer it in this thread because i dont think it will deviate too much from the topic. but next time it would be just as easy to start your own topic.
Old Mar 25, 2009 | 09:35 AM
PumkinSvt's Avatar
its for a 97 civic with a b18 motor.
Old Mar 25, 2009 | 10:34 AM
the Op's car or roll dogs? here are all the answers lol:
Trans mount: 90183-SR3-000
Rear Tq mount: 90165-SM4-020
the motor mount doesn't really have a big bolt through it like the 92-95 bolts.
I don if you need any other bolts, ie mount to engine or mount to tranny etc, but you can find all the info from http://www.bernardiparts.com/SearchOptions.aspx if u are looking for the big bolts that go through the mounts you can use either a 97 civic or what ever car the engine came out of, they should be the same.
Old Mar 25, 2009 | 11:33 AM
PumkinSvt's Avatar
Rolldogs lol Thanks man!
Old Mar 25, 2009 | 12:08 PM
The bolts that bolt the flywheel to the engine are: 90011-PH3-000 you need 8
The bolts that bolt the clutch to the flywheel are: 90034-689-000 you need 6
The bolts that bolt the trans mission to the engine are: i cant find them, none of the part drawings have them. maby some one else could find them...
potatointegra01
May 3, 2015 08:20 PM
lsvtek
Sep 29, 2008 11:45 PM
jweeks
Apr 16, 2007 06:39 AM
tattoo collector
Apr 4, 2006 07:55 AM
trigun7469
Dec 31, 2005 07:06 PM
