obd1 b18c1 into a em1
Old Mar 21, 2009 | 03:25 AM
mcvic's Avatar
Default obd1 b18c1 into a em1
Hello, ht I got a 99-00 civic si w/ The b16a motor and a few weeks ago my b16 motor blew on
Me But I'm currently looking at a obd1 b18c1 gsr motor I need to know what I need to do tis swap (turn it to a obd2) I know I will b using the injector, alternator, distrubutor, motor mounts and wiring harness from the b16 is there anything else I need and any stuff to rewire please help me if anyone can. Thanks
Old Mar 21, 2009 | 05:56 AM
jklnhd's Avatar
Default Re: obd1 b18c1 into a em1
umm, get an obd2 engine and make everything less of a pain. or just work with what you've got, build a long block and use your stock harness/ecu/etc & get it tuned.
Old Mar 21, 2009 | 12:11 PM
dafuzzbudd's Avatar
doing research with obd1 ls into obd2 this is how it goes:
1. injectors from obd2 can be reused
2. obd2 dizzy wont bolt, plug needs to be repinned, or buy conversion harness
3. crank pressure sensor: you can trick ecu to read it correctly
4. iavc needs to be rewired 2<->3
think that's it...
Old Mar 21, 2009 | 01:30 PM
ekb16's Avatar
just transfer the engine harness, injectors, dizzy, alt over to the gsr and everything should be plug n play..u will have to add a wire or 2 for the IAB if you are still using the gsr IM..as for the CFK sensor thats on the oil pump u can trick the ecu by splicing some wires together...u should run a obd2a gsr ecu since they dont have the immob.
appelsos
11
Jul 11, 2011 06:24 PM
cthan3o3
13
Jul 31, 2005 08:27 AM
JdMjOhNyO
Nov 2, 2004 02:54 PM
fastlude69
May 28, 2003 05:58 AM
Kid1320
Jan 18, 2003 05:21 AM
