need help with b20b engine swap
i have a 2000 civic ex. Im about to buy this b20b non-vtec swap it comes with
-Complete Block
- Complete Head
- Intake Manifold
- Wiring Harness
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor *
- Power Steering Pump *
what else do i need in order to complete this swap s i will have no problems so i can buy everything all together?
-Complete Block
- Complete Head
- Intake Manifold
- Wiring Harness
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor *
B series integra axels or 99-00 civic si axels.
B series transmission such as b16a, b16a2, b16a3, b18a, b18b, b18c, b18c1, b18c5
B series shift linkage
Bigger radiator hoses for top and bottom radiator
99-00 civic si rear T bracket
99-00 civic si driver side bracket screw
Upgraded aftermarket B series mounts for your car or use your stock mounts
B series clutch, pressure plate, throw out bearing, flywheel along with flywheel bolts and clutch and pressure plate bolts.
Ecu - you can use an ls manual ecu. p75 obd1
conversion harness from obd2b---->obd1
Reuse your original stock civic ex harness and sell the b20 engine harness or keep it for plugs
wow.
is their a site i can buy everything at?
do u think $950 is alot for a b20b non vtec?
if u know any where else let me know?
Also woulb i have to change my cluster as well.
how much u think a swap like this would cost.i went to a mechanic the other day and he wanted to charge me 1500 to do it plus buying engine.
Here is a good write up. If its obd1 then follow this. If obd2 then some sensors and dizzy etc don't need to be changed.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
