Hybrid Injector Swap
Old Mar 19, 2009 | 11:14 PM
hammergunner's Avatar
Default Hybrid Injector Swap
I was wondering if i could use the 345cc injectors off a h22a1?
I'm running a b18b1 with stock obd2 injectors(235cc), so am i in the green, or do the injectors even fit?
any info would be great, and please don't answer with a question...PLEASE.....
Thanks for helping my out homies!
Old Mar 19, 2009 | 11:22 PM
D16SiHatch's Avatar
Default Re: Hybrid Injector Swap
they should fit in your fuel rail fine, but without tuning you'll be running super rich. what do you want the bigger injectors for?
Old Mar 19, 2009 | 11:41 PM
Thanks, and as for the injectors, im running turbo, so im going to use the bigger injectors to accommodate the forced induction air flow, so i should run about even.
Plus this is more of a test then anything else. i mean R/C 440's are around $330 bucks here.
and im on a fixed income, so i doing a budget build, and new stock injectors are only $50 from the dealership brand new!
Old Mar 20, 2009 | 01:46 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
find used dsm 450's for 70 bucks or less on craigs list.
Old Mar 20, 2009 | 02:21 AM
id rather get the one's that are here locally and that i know are new and work
Never buy electronic motor parts on a second hand site..... always get them new and save yourself from pulling your hair out asking why your motor don't run.
Old Mar 22, 2009 | 04:23 PM
Loved
Community Favorite
never had a problem with used injectors.
just make sure they aren't dropped.
Old Mar 22, 2009 | 08:04 PM
jhammond_82's Avatar
Reject Papi
there's a guy in the mid atlantic marketplace that is very reputable, and would probably guarantee that they will work. i believe he's asking 60 shipped for dsm injectors. http://www.hondamarketplace.com/show....php?t=2430308
Old Mar 22, 2009 | 11:47 PM
the main reason i don't like used injectors is because they normally have build up or are clogged.
and a few i've had were burned out and didnt even work.
Reason i say never use used. is cuz you could drive yourself mad thinking something else is wrong with the motor, because you think your injectors Are suppose to work even if used.
one of my friends thought he burned out his ignition coil but it was really two bad injectors.
riceordie
Sep 7, 2011 11:29 AM
HondaKid936
Nov 13, 2008 07:16 AM
katb16vo
Apr 23, 2004 09:14 AM
jdmsijdm
Nov 28, 2003 05:07 PM
chris@allmotor.net
12
Aug 21, 2003 03:30 PM
