what size injectors should i run full N/A build help ?
Old Mar 19, 2009 | 10:38 AM
hondavtecsi1's Avatar
Icon2 what size injectors should i run full N/A build help ?
i have a stroked b16 a fully N/A build what size injectors should i run can anyone help ?
Old Mar 19, 2009 | 10:42 AM
SuckMyDOHC's Avatar
Default Re: what size injectors should i run full N/A build help ?
need more info. stroked to what? what cams? what valves? what compression?
Old Mar 19, 2009 | 10:58 AM
illusive's Avatar
310cc are normally good for most N/A builds if stock isnt cutting it.
Old Mar 19, 2009 | 11:09 AM
PreStaged12s's Avatar
http://www.phearable.net/tech/efibeginnerguide.html
Old Mar 19, 2009 | 11:21 AM
94c1v1cex's Avatar
get some 440's and you'll be set for any n/a build. even with some spray
Old Mar 19, 2009 | 11:36 AM
fast_4_door's Avatar
yup... rc 310 or some dsm 440's will do you just fine. just get that **** tuned regardless. beyond base map chipping your ecu.
Old Mar 19, 2009 | 10:32 PM
it has the same stroke as a type-r 3.433 stroke with stock valves ported polished head stage 3 blox cams and 13.2.1 COMP might put a 75 shot on not sure yet
hondapowaa
Apr 21, 2008 05:05 PM
alexb16hb
May 13, 2006 10:18 AM
bootlegtrader
Jun 24, 2005 10:19 AM
bootlegtrader
Jun 23, 2005 09:14 PM
k_bster24
Apr 2, 2004 06:50 PM
