shaved pulley?
Old Mar 18, 2009 | 11:51 AM
soodominican's Avatar
Default shaved pulley?
So my for those of you who have a shaved underdrive pulley, did you feel a difference? how much was it to get it shaved?
Old Mar 18, 2009 | 12:14 PM
h224thgensedan's Avatar
Default Re: shaved pulley?
Removing weight off of the crank snout isnt a great idea. Lots of horror stories about them. They can lead to oil pump failure, main bearing wear, ect.
Old Mar 18, 2009 | 02:46 PM
gearhead16's Avatar
if you want a lighter pulley go with the hona ctr n1 pulley only! others cause balance problems
Old Mar 18, 2009 | 03:52 PM
well one point for ctr pulley
Old Mar 18, 2009 | 04:29 PM
Dark_Teg's Avatar
Myth:
Oil pump failure-There isnt a logical explanation to support those peoples claims.
Main bearing wear-Less weight on Crank=less bearing wear.
Engine out of balance-The pulley on a honda is not a harmonic balancer.
*I did lots of research and couldnt find a real reason not to run a lightened crank pulley.
Old Mar 18, 2009 | 04:39 PM
SOHCinWA's Avatar
Originally Posted by Dark_Teg
Myth:
I run a 1.5lbs one on my d15. It revs to 9000+rpm. 2 years and 100+ passes with no issues.
Old Mar 18, 2009 | 04:44 PM
JOE BD-0's Avatar
a neatly shaved pulley looks and feels great!
Old Mar 18, 2009 | 04:48 PM
eddie31003's Avatar
what the?! thought it said something else was shaved...
Old Mar 18, 2009 | 05:11 PM
grog's Avatar
ctr pulleys are solid metal where as a shaved pulled would still have the harmonic dampener ( it has rubber in the middle.
you wont feel the difference.
oh and if anybody does shave their pulley make sure to have a machine shop re balance the pulley (on its own) btw this is the same idea as balancing tires except they will remove weight by drilling holes from the heavier portion.
i think i spent $80 on the labor.
Old Mar 19, 2009 | 07:21 AM
fireant's Avatar
I've been happy with my shaved pulley from here:
http://hondamarketplace.com/showthread.php?t=1810330
The CTR N1 is not dampened... its no better than getting an aftermarket one from UR.
Fluidampr makes them for B-series with dampers.
Old Mar 19, 2009 | 11:08 AM
Crx Jimmy's Avatar
I had the mine done by dunkd (cody) too ^^. Mine is the ls crank pulley shown on that page.
Old Mar 19, 2009 | 02:39 PM
damn, so shave or not to shave, that is the question lol... i'm just doing a maintenance/rebuild on my motor because i have rod knock. and im taking the motor out to just ALL the bearings as opposed to just the rod bearings. and in the process i wanted to spice it up a bit, lightweight pulley, lightweight flywheel ( still have an ls transmission) and a clutch. along with new front and rear main seals of course. it only has 65K so i dunno if ill replace the rings but if i do i might as well change the pistons too
ghostriderinnc
Jun 27, 2010 05:29 AM
melovesboost
Feb 25, 2007 02:30 PM
turboD_EG
Nov 30, 2006 06:45 PM
NateTEG95
May 30, 2003 09:24 PM
