Shift cable replaced and check engine light now coming on???
Old Mar 14, 2009 | 09:17 AM
jw 1's Avatar
Default Shift cable replaced and check engine light now coming on???
I just had my shift cable changed on my 92 Accord automatic.
Now the car is hard to start if it starts at all and the check engine light now comes on?????
When I turn the ignition switch on it appears to go through a self check then the D4 disappears. After several attempts the car starts and the check engine light comes on!
I have checked all connections and everything appears to be in place.
What could it be?
I have also tried to reset the computer by removing the pos battery lead for over 10 minutes, Not because I think it need it but because I need it!
Thanks
Old Mar 14, 2009 | 10:08 AM
nothing_shocking's Avatar
Default Re: Shift cable replaced and check engine light now coming on???
wrong forum, but it'd help if you knew what the CEL error is
Old Mar 14, 2009 | 10:28 AM
jw 1's Avatar
I am assuming the code under the passengers seat?
It is flashing 8
8 at about a second each.
Old Mar 14, 2009 | 10:39 AM
i'll just PM you since this is the wrong forum
ElCivic89
Apr 22, 2012 09:02 PM
nyzd79
Nov 22, 2007 03:42 PM
alexb16hb
Nov 19, 2005 10:20 PM
c.dub
Mar 6, 2005 08:49 PM
