how to remove passenger airbag?
Old Mar 13, 2009 | 11:15 AM
Goosse's Avatar
Default how to remove passenger airbag?
Hi guys, I'm redoing the interieur on my hatch and I wanted to remove the passenger airbag. I removed all the bolts on the underside of the airbag, but I can't remove the block off plate on top of the dash. Are there any tricks to do this? Any help is appreciated.
btw: car is a 97 civic
Old Mar 13, 2009 | 11:30 AM
Valpo500's Avatar
Default Re: how to remove passenger airbag?
same question here... someone???
Old Mar 13, 2009 | 11:57 AM
teamworxek9's Avatar
if all the bolts are out and its unpluged, just put a pry bar between the bottom of the airbag and the bar under it pry up till it pops out. how i did mine.
Old Mar 13, 2009 | 12:00 PM
cracker1252's Avatar
i read this in another post, but i cant find the dam thing. just remember it saying: "dont pry from the top, pry from the bottom after you remove the plug, and it will pop right out, in tact."
Old Mar 13, 2009 | 12:03 PM
yes from the bottom, dont touch the top it takes some force.
Old Mar 13, 2009 | 12:32 PM
Goosse's Avatar
but can you reach the bottem? it seems that the airbag itself is in the way? I'm sure to give it a try.
Old Mar 13, 2009 | 01:39 PM
92-CivicLX's Avatar
I would be scared to pry it open...lol
Old Mar 13, 2009 | 02:07 PM
POE's Avatar
POE
were is this plug located? i would like to simply just unhook my passenger side..
sorry to thread jack..
free bump
Old Mar 13, 2009 | 02:17 PM
its in yellow loom follow it form the air bad to the yellow plug. and there is a metal plate under the airbag that you pry on.
Old Mar 26, 2009 | 07:46 PM
96civic_hb's Avatar
You have to pry like a mother ****er, I pryed on mine with a screw driver and the **** broke. So pry hard!
Old Apr 2, 2009 | 01:33 PM
94exinsanecivic's Avatar
Thanks I was wondering the same.
Old Dec 11, 2012 | 02:30 PM
JimmyNeutron99's Avatar
i am also looking for some info on this subject, i just picked up a 94 del sol and it was in a fender bender, both air bags are deployed i know how to do the driver side but i cant figure the pass. side never done it, where are the screws located for the airbag? any info would be great and i as well am sorry for hijacking the post i just need to know lol
Old Dec 11, 2012 | 02:36 PM
johnlvs2run's Avatar
Take off the door to the glove compartment, and you can see the screws for the airbag.
jason_v2
Mar 1, 2009 08:00 PM
hondastrtracr
Feb 28, 2008 08:41 PM
shaunk18
Sep 20, 2007 12:26 PM
sk3ch
Sep 2, 2007 05:06 PM
FONK
Dec 6, 2005 06:04 PM
