Found this:DIY: Modify K-Series Injectors to flow 490cc and 520cc
Old Mar 13, 2009 | 05:53 AM
namewasdallas's Avatar
Default Found this:DIY: Modify K-Series Injectors to flow 490cc and 520cc
was looking around on some other boards and found this to be a real easy method to make your k20 injectors flow more without having to buy new ones. I will give credit were credit is due so thank chunky @ k20a.org
Debate and disscus
http://www.xproductionz.com/forum/showthread.php?t=3769
Old Mar 13, 2009 | 08:50 AM
locash's Avatar
Default Re: Found this:DIY: Modify K-Series Injectors to flow 490cc and 520cc
Make sure that if you do this mod, you get the injectors flow checked afterwards. That way, you know that all of the injectors are working properly, and you will know the individual injector trims..
Old Mar 13, 2009 | 12:35 PM
dcvt16's Avatar
i wonder how the spray pattern is after this mod.
Old Mar 13, 2009 | 12:57 PM
DELTEGRA's Avatar
My thoughts exactly....... interested to know myself
Old Mar 14, 2009 | 01:54 PM
dcvt16's Avatar
i would like to see this discussed...
Old Mar 15, 2009 | 08:26 PM
SI_frankenstein's Avatar
I wonder if you could do this to other injectors???
Old Mar 19, 2009 | 06:25 AM
bump for the k20 people
Old Aug 30, 2010 | 09:10 AM
Garrett's Avatar
Hi guys, last week I did the test, on dyno
I used a civic si 2008 with stock k20z3, and hondata flashpro
the car as a ASP race header, SRI with BPI stack, and a custom 3'' SS exhaust
I did the whole tuning and the results is run40
I change the injectors and replace for a set of stock 310 cc k20a2 injectors, with the nozzle cap removed
I only do a fuel trim resize to 510 cc (to reach the same AFR)
the results are here (run45)
the part throttle AFR was really after this, so a complete tuning need to be done
Old Aug 30, 2010 | 08:22 PM
uberEFtuner's Avatar
That does not make sense. If you have a garden hose at 10psi with a bunch of small holes, It will flow just a much as a garden hose with one big hole at 10psi. Making the hole bigger does not affect the quantity of fuel coming through. Bigger fuel injectors have an overall bigger width to allow more flow and a bigger coil to handle being open longer.
Old Aug 31, 2010 | 06:10 AM
Garrett's Avatar
the end cap, restraint the flow, with this cap remove, the pressure still the same, but we need to resize, since more fuel is injected
I try it, and see by myselft the results
TokuiAutowerks
Jun 19, 2008 06:02 PM
all-mtr-teg
Apr 16, 2007 08:32 PM
mprelude
Nov 27, 2004 03:25 PM
96redgsr
Jul 21, 2004 09:46 PM
TurboJesse
Jun 29, 2003 04:31 PM
