Wierd electrical problem, Radio turns off when headlights turn on? *going nutts
Old Mar 10, 2009 | 09:01 PM
djeclipzjv's Avatar
Icon2 Wierd electrical problem, Radio turns off when headlights turn on? *going nutts
wussup guys, i've been trying to figure out why my car radio turns off when i turn on my headlights. It all started back when i installed the radio, one of the wire came loose and i guess it touched the ground line so i blew 2 fuse out. So i replaced it, everything works fine now, but after that, everytime i turn on the lights, radio shuts off, there is no radio clock power to it. The radio memory is wiped out everytime i turn on the lights. I checked all the fuse, all seems to be good. Its driving me nuts having to drive around at night with no music. If you can guys can shoot me some tips, greatly appreciated, 2000 Civic Si
Old Mar 10, 2009 | 09:12 PM
bluebomber's Avatar
Information Leafblower
Default Re: Wierd electrical problem, Radio turns off when headlights turn on? *going nutts
I had a similar problem when I installed my first radio 7 years ago. It turns out when I made my wiring harness for the radio, there was an orange wire that I didn't tape off (it wasn't used), and the metal in the wire was touching a metal piece behind the dash, shorting out my fuse every time. I taped the wire, and everything was fine after that.
Might want to check and see if you've got a similar issue.
Old Mar 10, 2009 | 09:18 PM
djeclipzjv's Avatar
ohkay. thanx alot blue bomber! i will check asap tomoro. I hope thats the case, i remember checking last time for any wires but didn't find any besides the one i taped up. Thanx again
djeclipzjv's Avatar
Open for any other tips!
Old Mar 11, 2009 | 08:23 AM
djeclipzjv's Avatar
bump
Old Mar 11, 2009 | 09:22 AM
civicgsr's Avatar
That's pretty much it (unless you're talking about an old MG!).
Old Mar 11, 2009 | 09:12 PM
djeclipzjv's Avatar
ohkay. i checked it today. all the wires seem to be sealed up. One of my friends told me it might be a fuse, he said it might be a weak fuse thats why it cuts off everytime. I will look into it. but i am still open for more suggestions. thanx guys!
Old Mar 12, 2009 | 07:42 PM
djeclipzjv's Avatar
bump
Old Mar 12, 2009 | 08:23 PM
siboosted's Avatar
sounds like you have your ground is hooked up to the illumination wire. did you use a wire harness or is it straight wired to the factory wires. the factory illumination wire is red with a black strip. it acts as a ground with your lights off but when they are on it has 12 volts. usually the cause of the described problem.
Old Mar 12, 2009 | 09:15 PM
djeclipzjv's Avatar
Si Boosted i think you hit it on target. When i got my radio i got sorta excited and said screw the harness so i just cut up the wires and wired it myself. I think thats exactly what i did because i remember a red wire with black. Im going to check that ASAP tomoro. Thans alot man, i think that will solve the problem. Much appreciated.
Old Mar 14, 2009 | 05:24 PM
djeclipzjv's Avatar
HEY Si Boosted, YOu nailed it on target. My ground was hooked to the red wire with black stripe. I changed the ground wire and everything is back to normal. woot! thanx alot man.
Old Oct 10, 2015 | 12:18 PM
Johncivic3's Avatar
I'm really not sure how old this post was but I'm running into the exact same problem I hooked up my wideband O2 sensor and gauge, without disturbing the wiring harness radio which has been connected through over two years and never had a problem, now all the sudden when I turn my lights on the radio turns off now all the sudden when I turn my lights on the radio turns off... Any idea
Old Oct 11, 2015 | 11:38 AM
NotARaCist's Avatar
I never narc'd on nobody!
6 year old thread
First off, never bump an ancient thread without a damn good, directly related reason. Your reason is neither good, nor directly related. Second off, you obviously wired something wrong.
b18c inside
Dec 13, 2011 05:34 PM
ryanhauk
May 20, 2009 06:01 PM
CaseBone
Mar 13, 2006 04:57 PM
Crasian
10
Jun 9, 2005 09:06 AM
glock
Audio / Security / Video
Feb 1, 2002 09:36 PM
