turn signal problem HELP!!!!!!!!!!!!!!!!!!!!!!!!
so the other day i was my fog lights werent working so i was trying to find the problem. ended up being a fuse, but anyways my hot wire that plugs into my fuse box under my dash, i was trying to push it underneith my dash and i touched it to the fuse box or something near it and poped some fuses.
so i replaced the fuses and after i did my turn signals are doing something weird. they work fine with the headlights off and with the running lights on. but when i turn the **** to that final click when my headlights come on, the driver side turn signal doesnt work anymore. and when turn my brights on the driver side turn signal is on all the time. it doesnt flash but it is just on.
so i checked all of my fuses and they are fine, i even checked the ones underneith my hood.
Any suggestions? its a 97 civic coupe with a b16a swap.
thanks
thanks
Re: turn signal problem HELP!!!!!!!!!!!!!!!!!!!!!!!!
yeah that was it. i just took it out and put it back in so that it would get a good metal to metal contact. thanks man it also fixed my headlight that would turn off when my brights were on and it was dim when it was just on. thanks again
Kellybaraka
02-11-2016 08:55 PM
