... abs light comes on at 2-5 mph (did search on abs)
Old Aug 12, 2002 | 09:47 AM
1.8T_EG's Avatar
Default ... abs light comes on at 2-5 mph (did search on abs)
((new to the board, woah, i think i found a new home, the best threads i've ever seen))... anyways
did search, not what i was looking for
94 civic ex, just got a gsr swap, at startup the abs light is off, then around 2-5 mph, it comes on and stays on until the car is shut down... anyone had this happen to them?... anyone have any ideas?... thanks in advance...
Old Aug 12, 2002 | 03:40 PM
Chiovnidca's Avatar
Default Re: ... abs light comes on at 2-5 mph (1.8T_EG)
What codes are stored?
Old Aug 12, 2002 | 06:32 PM
BreakStuff's Avatar
New User
If the ABS lamp illuminates then goes "off" when the car is first started, then the ABS system passed the intial test and the system checks ok...
If you begin driving the car and the lamp illuminates, then there is a clear indication of a bad wheel sensor, bad/chipped sensor pickups, wheel drag or possibly a bad wheel bearing... It would be easiest to check the code and inspect the affected wheel...
Old Aug 12, 2002 | 06:36 PM
hondafrk's Avatar
Default Re: ... abs light comes on at 2-5 mph (BreakStuff)
Old Aug 12, 2002 | 07:44 PM
minime's Avatar
Default Re: ... abs light comes on at 2-5 mph (hondafrk)
did your swap come with axles with the abs ring on the outer joint? probally not!
Saadi1786
Honda Fit
Dec 4, 2018 03:51 PM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
spooncivic1
Jan 11, 2006 08:09 PM
typesguy
Suspension & Brakes
Nov 7, 2005 06:24 AM
Dirt
Jun 6, 2002 05:16 AM
