Quick radiator question
Old Mar 9, 2009 | 11:09 AM
zach1288's Avatar
Default Quick radiator question
Today i went to the store and came back and decided to check my fluids. When i took off the radiator cap some coolant overflowed onto the ground. Is that normal? I am running at regular engine temperature?
Old Mar 9, 2009 | 11:12 AM
Ser1N's Avatar
Default Re: Quick radiator question
If its hot its always going to spray out, be careful it can spray at your face.
next time wait till its cold to check.
Old Mar 9, 2009 | 11:13 AM
Adankid's Avatar
yeah thats totally normal.
you opened up the radiator cap right after you were running the engine for a while right?
Old Mar 9, 2009 | 11:19 AM
zach1288's Avatar
Yes, i'm stupid
Old Mar 9, 2009 | 11:26 AM
centralman's Avatar
I think when you car is cold check the coolant level in the reservoir should be alright unless there's nothing then you will need to take off the cap and check the level inside the rad.
Old Mar 10, 2009 | 05:29 AM
zach1288's Avatar
Do i need to burp the system now?
Old Mar 10, 2009 | 05:44 AM
DRAMA's Avatar
when burping the system, the engine needs to be running at warm optimal temps with the cap off
Old Mar 10, 2009 | 08:15 AM
EL Vap133's Avatar
Never open it with the engine hot, I can tell you from experience that it will burn and hurt like a ****!!
Old Mar 10, 2009 | 10:28 AM
iliv2xlr8's Avatar
Water expands when heated, go figure.
Yes, you purge they system by removing the cap when the engine is dead cold. Start the car and the air bubles will surface. Let the engine warm up and all the bubles will be gone.
TehGhett0P1mp
Mar 6, 2010 08:42 PM
cehcivic15
Jul 4, 2008 11:51 AM
smokerz212
Jan 8, 2007 05:13 PM
acuracy r
Apr 14, 2005 06:24 PM
PreIudeSI
Sep 2, 2002 04:50 PM
