The weak d16y8
Old Mar 8, 2009 | 01:03 AM
SlowEJ8's Avatar
Default The weak d16y8
I'm pretty upset at the d16y8 engine...
Drove down the freeway today and some eg was coming up quick(heard his fart can)
I decided to run it with him on the freeway, didn't know what was in it.
He coulda smoked me by a mile if he wanted to.
To get to the point... Why do d16y8 engine vtecs feel so freaken weak?? is it because of the SOHC?? or what is it??
Old Mar 8, 2009 | 01:08 AM
hoffmanb16's Avatar
Default Re: The weak d16y8
yup, vtec works better with 2 cams cause you can get more rpms out of the motor.... and it's all about the rpms
Old Mar 8, 2009 | 01:10 AM
hoffmanb16's Avatar
he was likley in his rpm range and you were not, kinda hard to run him down when he is at 6k and your at 4, he likely had a b series too.
Old Mar 8, 2009 | 01:15 AM
SlowEJ8's Avatar
I drive an automatic, so i already had my pedal all the way down to the ground, going at like 90-100. He came next to me revved and took off. I felt so embarassed. haha
Old Mar 8, 2009 | 05:50 AM
Kista20's Avatar
streetracing ftl maybe the other car didn't have a d series, if he smoked you that bad sounds like he has a turbo or also had a motor swap done, heck maybe even both.
Old Mar 8, 2009 | 07:53 AM
thumper64's Avatar
You drive an auto, that's part of it. The torque converter doesn't lock up 100%, so you'll never transfer what power you have as well as a clutch. And the stock tranny is going to shift at the best time to keep fuel economy up, since that's what your car was made for. Besides, the SOHC engines aren't all that powerful. It's (assuming) a stock 1.6 liter, what do you expect from it?
Old Mar 8, 2009 | 08:59 AM
batallic's Avatar
u had auto, tall gearing, it is SOHC, its weak unless u boost and go manual
Old Mar 8, 2009 | 09:37 AM
Townson's Avatar
join the club. lol.
Old Mar 8, 2009 | 09:45 AM
GSR-EG-92's Avatar
It was built to go to the grocery store and back. When I dynod my Z6 before I pulled it, she was making 91 hp. It was old, but still. SOHCs have VTEC on only one side (dont remember if its the I or E) so your losing out there too.
Old Mar 8, 2009 | 11:38 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Problem solved.
Old Mar 8, 2009 | 11:45 AM
Schister66's Avatar
Man U FTW
You have a small bore, long stroke 1.6L SOHC automatic. There are several things wrong with that list. That's not to say D's can't be fast, but with an Auto, it's impossible. Swap a manual and boost it...you'll believe in the SOHC again after that
Old Mar 8, 2009 | 11:59 AM
[Rawk.Star]'s Avatar
New User
Originally Posted by Vindicator9000
Problem solved.
Lol. Pretty much. ^_^. I used to have a mazda protege that was an auto.. It was slooow. Swapped the trans for a 5 speed from a donor car at a junkyard.. It was still slow as hell, but it felt better to be able to drop gears and what not.
It sucks to "try" to make pulls in auto cars.. especially an auto d16. Heh. Trans swap? ^_^
Old Mar 8, 2009 | 02:14 PM
hatchnideas's Avatar
nothing wrong with the y8... i beat lots of mid 15 second cars with the one i had. autotragic tranny is for old people though really.
Old Mar 8, 2009 | 02:30 PM
dondirt's Avatar
lol
Old Mar 8, 2009 | 02:35 PM
waynecoSI's Avatar
Originally Posted by dondirt
lol
lol
Old Mar 8, 2009 | 03:29 PM
Dkober101's Avatar
not a big fan of the y8's i had one spin a rodbearing on me and from what i was told by H-T they are known for this problem
Old Mar 8, 2009 | 03:36 PM
trustdestruction's Avatar
Yep, the problem is definitely that you have a slushbox. The D16Y8 isn't that bad, and it does have potential. However, your automatic transmission is what's keeping you even slower than normal.
If you read the write up on how Torque converters work in the FAQ, you'll understand why the automatic sucks for power.
Old Mar 8, 2009 | 03:39 PM
ALLxMOTOR EG's Avatar
Vietnamese!
What he said.
Old Mar 8, 2009 | 04:36 PM
tx_ej8_49's Avatar
Word.
Manual swap and boost it. Then no stock EG with a fart can should rape you on the highway. Upgrade your oil pump thought. Y7/Y8 oil pumps are crap. Ive seen more rod knocking y7/y8 than i ever wanted to.
Turbod16.com
D-series.org
Best d-series info you will ever get. I hate to say it but most hater-tec....honda-tech members are b/h/f/k fans...But you can still get alot of good info here. Most old school members know what the hell they are talking about.
Let the flaming begin.
Old Mar 8, 2009 | 06:24 PM
batallic's Avatar
Vtec is on intake side for sohc
Old Mar 8, 2009 | 09:47 PM
ifIexplode's Avatar
LOL @ stock y8 highway pull
Old Mar 9, 2009 | 12:09 PM
mattkins91's Avatar
I like my y8......just thought id throw that out there lol
jz2518
Mar 24, 2015 07:33 PM
S u b Z e r o
Jan 27, 2014 03:51 PM
Killa From Manila
Mar 6, 2007 11:28 AM
jdanger
12
May 12, 2004 10:43 PM
