looking for somebody to help with car
Old Mar 6, 2009 | 09:17 AM
patric8332's Avatar
Default looking for somebody to help with car
willing to pay for haveing somebody help with car i have a 93 civic im sure most people on here has seen it well the other day the speedo went out thought it may be the vss changed it nothing, thought it may be the cluster changed it nothing, thought it may be a a bad vss plug on the harness changed it nothing, so idk what it could possibly be...the guy that actually built the car and knows everything about it wont answer my phone calls or anything so im trying to see if i can find anybody else out there that knows what their talking about...im located in Manchester TN im looking for somebody local or atleast in short driving distance thanks
Old Mar 6, 2009 | 11:57 AM
GSR615's Avatar
Default Re: looking for somebody to help with car
has it work before ? could be the wiring on the gauge cluster .
or have you changed out the vss itself
Old Mar 6, 2009 | 12:11 PM
mr4dr.'s Avatar
my buddy had the same prob a couple years ago.. and i believe it was a fuse.. give them all a look over
Old Mar 6, 2009 | 12:25 PM
fakieSI's Avatar
lol im that buddy and all it was... was a fuse...
Old Mar 6, 2009 | 01:59 PM
patric8332's Avatar
do you know which fuse it was?
Old Mar 6, 2009 | 02:17 PM
mr4dr.'s Avatar
nope..its been awhile but just pull out and look over every fuse.. will only take a couple mins
Old Mar 6, 2009 | 02:36 PM
patric8332's Avatar
alright thanks man
Old Mar 6, 2009 | 02:47 PM
patric8332's Avatar
all fuses were checked and all were fine so idk im stumpped on this one
Old Mar 6, 2009 | 02:51 PM
mr4dr.'s Avatar
hmmmmmmm.. maybe check the fuse box under the hood
Old Mar 6, 2009 | 02:58 PM
patric8332's Avatar
negative...all those fuses were intact also no blown ones
Old Mar 6, 2009 | 03:04 PM
mr4dr.'s Avatar
well hellllllllll.. i was sure that was going to be ur problem too.. anyways gl with that
Old Mar 6, 2009 | 03:17 PM
patric8332's Avatar
thanks for the help man
mr4dr.'s Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/
to answer your question earlier
the "Alternator/SP Sensor" fuse was the one that was bad in fakieSI's car
Old Mar 6, 2009 | 06:36 PM
j390s's Avatar
check your fuses with a test light looks may sometimes be decieving
Old Mar 7, 2009 | 07:09 AM
jrscb16eg6's Avatar
actually if your checking them correctly you need to use a volt meter to check the voltage of the fuse's...ive had a couple cases were fuses look good and test good on a test light but on a volt meter.one side will read low voltage
Old Mar 7, 2009 | 07:39 PM
h22-hatch's Avatar
lol dammit patric....call me, and bring it down to my house and i have an idea...ive been through that with my old coupe...just hit me up
chicklet
Sep 11, 2016 08:11 AM
ctr-ek
Apr 10, 2008 07:33 PM
Midori Green
Jul 20, 2007 11:24 AM
H Tuning
10
Sep 27, 2006 11:16 AM
jdm2teg
Feb 21, 2006 08:38 PM
