cluster problems!! help!!
Old Mar 20, 2008 | 09:50 PM
ctr-ek's Avatar
Default cluster problems!! help!!
ok i recently threw in a single cam into mah eg hatch to use as a daily now i started up the car and the cluster was working perfectly i turn off the car and when i go back to start it back up the rpm, speedo and fuel/temp gauges didnt work at all. Another thing i noticed was that it wasnt reading the CEL when u first turn the ignition on. It only reads the battery and SRS. I've checked the fuses under the hood and dash, they're all good. I checked the speed sensor and it was good. I also swap out the cluster and tried another one and it didnt work either. I even switched the ecu to see if it couldve been that and it wasnt!! im goin crazy trying to figure this out ive been at it for days now and im stuck! Can ANYONE help me out?!??! Like i said i use this as a daily and im always traveling do to my job so i need to know my fuel level and temp on the car!! HELP PLEASE!!!
Old Mar 21, 2008 | 10:27 PM
ctr-ek's Avatar
Default Re: cluster problems!! help!! (ctr-ek)
helllppp!!
Old Mar 21, 2008 | 11:55 PM
civicstar's Avatar
did you check the harness plug on the driver side near the clutch resevoir
Old Mar 22, 2008 | 06:40 AM
ctr-ek's Avatar
Default Re: cluster problems!! help!! (civicstar)
i did check and everything is plugged in
Old Mar 23, 2008 | 08:45 AM
ctr-ek's Avatar
someone please help me out
Old Mar 26, 2008 | 07:35 PM
ctr-ek's Avatar
sooommmmeeoooonnnne hhheeellllllllllpppp
Old Mar 29, 2008 | 08:21 PM
ctr-ek's Avatar
can anyone help?
Old Mar 29, 2008 | 08:27 PM
vlang29's Avatar
check ecu ground
Old Apr 3, 2008 | 08:32 PM
ctr-ek's Avatar
Default Re: cluster problems!! help!! (vlang29)
will do
Old Apr 6, 2008 | 07:58 PM
ctr-ek's Avatar
still stuck with this problem!!
Old Apr 9, 2008 | 08:52 PM
GErippenARS's Avatar
Could it be a faulty ECM. Its in the dash under the steering wheel. I believe this is the control module for the electrical. are the relays clicking when you turn the switch to the on postion???
Old Apr 10, 2008 | 07:33 PM
ctr-ek's Avatar
Default Re: cluster problems!! help!! (GErippenARS)
clicking wen i turn on the ignition? if thats wha u mean then no i dont hear any clicking
B_Swapped93
Jul 18, 2013 03:56 AM
5speeder
Feb 22, 2012 07:01 AM
floridaEg8ferio
Jul 12, 2011 06:09 PM
Dc295kid
Mar 27, 2009 07:32 AM
mugencivic94
Aug 17, 2007 09:54 AM
