Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Check engine light came on!
Old Mar 5, 2009 | 07:28 PM
8_UR_AWD's Avatar
Default Check engine light came on!
So I was working on my friends 01 and the check engine light came on! All I did was pull her stereo out and put it back in... its an after market sony unit. Any possible ideas? I pulled on the stereo harness to get some room but nothing else? Need a response asap!
Old Mar 5, 2009 | 07:41 PM
unevolved's Avatar
Default Re: Check engine light came on!
It's an OBDII car. It's an incredibly complex piece of machinery.
Obviously throwing a CEL isn't something that should normally happen when you change out the radio, so this isn't a common solution. We're not going to be able to diagnose this over the internet. Go to Autozone and have them pull the code and go from there.
It's a dumb question, but are you sure it's the Check-engine light and not the maintenance required light?
Old Mar 5, 2009 | 07:50 PM
EM24's Avatar
u should have someone try an run a scanner on it, tells u everything
Old Mar 5, 2009 | 07:51 PM
Jas9848's Avatar
yea a scan tool works wonders!!
Old Mar 5, 2009 | 07:52 PM
homelessEm2's Avatar
actually you can diagnose it here. there is a diagnostic port you can take a paper clip and put it in plug 4 and 9 i believe and turn the key on and your CEL will blink. follow the blinks and match the numbers to the code. try that
http://k-series.com/tech_document.php?id=37
http://k-series.com/dtc.html
Old Mar 5, 2009 | 07:55 PM
EM24's Avatar
i have never tried a paper clip before sounds like it works tho
Old Mar 5, 2009 | 08:23 PM
Jas9848's Avatar
yea there is a plug you can do that to like on older hondas. i forget where it is on an em2, it's been awhile.
Old Mar 6, 2009 | 03:52 AM
ive personally done it in mine and a couple other 7th gens, its easy and accurate
Old Mar 6, 2009 | 08:51 AM
Whatislove's Avatar
Autozone gives you free readings. go there
Old Mar 6, 2009 | 12:38 PM
8_UR_AWD's Avatar
Good news! She drove the car to school this morning and it shut off!
Old Mar 6, 2009 | 12:46 PM
EM24's Avatar
that sounds like a problem with a air sensor or something, if it's going on and off
Old Mar 6, 2009 | 02:10 PM
jdmfreak1992's Avatar
You running an aftermarket intake? Bc I just posted a thread about that and Ik that the aem one pulls on the wires going to the IAT sensor which thanks to homeless I was able to fix it. But first go get the codes.
Old Mar 8, 2009 | 02:55 PM
350oshin's Avatar
what scanner did u use
Old Mar 8, 2009 | 06:19 PM
8_UR_AWD's Avatar
no intake... its all stock. Thanks for all the help guys!
haynesbc
Mar 2, 2008 12:22 PM
SiTR
Feb 14, 2008 04:19 PM
jaycapz
Jan 22, 2005 02:29 PM
sackdz
Jun 23, 2001 09:36 AM
