Check Enging Light - How to get code
Old Jun 23, 2001 | 09:20 AM
sackdz's Avatar
Default Check Enging Light - How to get code
MY CEL went on, I jumpered the plug hanging up above the ECU, then turned the ignition on. No blinking. Doesn't the light just come on regularly to try to get people to take it in to the dealer? That the little button under the dash (driver's side) you use to reset?
Old Jun 23, 2001 | 09:36 AM
blaze's Avatar
Default Re: Check Enging Light - How to get code (sackdz)
is it the "check engine light" or the "maintenance required" light?? because if it is the check engine light and you jumpered it correctly, it should flash telling which code your getting.... the little button underneath resets the "maintenance required" light. hth
BiggieBert
Acura TL, RL & ZDX
Sep 20, 2008 08:59 AM
Corruption
Jun 3, 2006 12:08 PM
laurat
Oct 14, 2002 12:54 PM
VTECVillain
Jan 6, 2002 11:40 AM
under_psi
Aug 16, 2001 12:50 PM
