My CRX is dead!
YEsterday morning i got in my car to start it. it turned over once and then when i went to turn the key again it went completely dead! i tried jump starting it last night and i got no power at all!!! can someone please help me!
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
Also check the main underhood fuse, but it is probably one of the above connections. If you aren't getting any power to your accessories either, it is the underhood fuse or connection at the battery. Was there alot of corrosion on the terminals?
re-check your connections, check if the ground is grounded 100% on the body
i had my ground fall off and i overlooked it, cuz i was just looking at the connections on the battery terminals..
sweet! so messed around with the ground wires and put my battery back in and it started! w00t w00t! thanks to all! one quick question are my wires suppose copper or are they suppose to be rusted a bit?
IT'S THE TIMING BELT. maybe. that happened to my cousin's prelude. he changed everything that could be the problem, then he found out the timing belt was broken.
vlc92189
42
Apr 24, 2009 06:06 AM
ace42004
34
Apr 11, 2005 02:57 PM
