question about gas
Old Mar 3, 2009 | 07:10 PM
EGed up from the seat up's Avatar
Default question about gas
ive heard that if you got a b16 you gotta fill it up with 91 gas, i barely got my car it has a usdm b16 ive filled it up once with 87, and i wanna clarify to make sure i can put 87 and i dont have to put 91.
Old Mar 4, 2009 | 03:19 AM
GhostAccord's Avatar
Default Re: question about gas
Check the owners manual and use the octane rating that it says to use.
If you use a lower grade than recommended you could see poor performance and fuel economy. Due to knock timing retard. If you run low octane in a high compression engine you may start to hear a knock. If a knock sensor detects this it will retard timing. Over a prolonged period this is not good for your engine or your fuel economy. It would probably be cheaper just to by 91 in the end.
Old Mar 4, 2009 | 03:38 AM
NYabstrak78's Avatar
u have to use 91 or better for vtec ... or your motor will dislike u
kahriak
Acura TSX
Feb 10, 2008 12:45 PM
vandersmissenc
18
Nov 10, 2005 10:17 PM
Train
Jan 31, 2004 07:19 PM
jdmillusion
Jul 19, 2003 09:07 PM
purpl7duece
Nov 16, 2002 01:15 PM
