Replaced eg's front turn signal bulbs, all four are stuck on... any ideas?
Old Mar 3, 2009 | 05:58 PM
Bambooseven's Avatar
Default Replaced eg's front turn signal bulbs, all four are stuck on... any ideas?
I had a turn signal bulb that was out in my new beater so I bought some new ones...
I took the one that was bad out and it was actually shattered in there...
I replaced both bulbs...
now all 4 corners are stuck on as well as the green arrows on the dash...
not fuses or relays, checked em.
any other insight?
Old Mar 3, 2009 | 06:09 PM
dohcdelsol's Avatar
Default Re: Replaced eg's front turn signal bulbs, all four are stuck on... any ideas?
are they on or flashing on? anything up with the hazard button? does it do it with the lights on and off? you def used the correct bulb, 1157 i believe?
Old Mar 3, 2009 | 06:17 PM
Doeboy's Avatar
You dont have the right bulb.
Old Mar 3, 2009 | 07:37 PM
everythingwentblack's Avatar
that happened to me actually. It starts with the wrong bulb, and then when i switched them out everything was still effed up. As it turns out it caused a fuse to blow as well.
Old Mar 3, 2009 | 08:40 PM
bulb was one number off. thanks guys.
TimVanScyoc
Mar 31, 2017 03:22 AM
OldskoojdmDA9
Jul 6, 2009 03:11 PM
jshi182
Dec 31, 2004 12:13 AM
1Tym
Jun 19, 2003 06:12 PM
B16ED4G
Feb 27, 2002 07:43 AM
