02-03 vs. 04-05 headlights
Old Mar 3, 2009 | 01:50 PM
Nate13's Avatar
Default 02-03 vs. 04-05 headlights
I heard you can put 04-05 headlights on an 02-03 Ep3? Whats modifications are involved cause i know its not a bolt up right?
Old Mar 3, 2009 | 02:38 PM
03K20A3Si's Avatar
Default Re: 02-03 vs. 04-05 headlights
I did it to my 03 Si. All you need to do is modify a few connectors and add plugs for the 9005 and 9006 bulbs. The turn signal and city lights need the connector modified to make it plug together. If you put the 04-05 bulb socket next to your 02-03 harness connector, you'll see what I mean. Then you have to turn your H4(9003) connector into separate 9005(high beam) and 9006(low beam). These connectors can be found at any auto parts store Just make sure you keep checking your wires for power with a test light to avoid mistakes. Make sure you use perma-seal connectors to connect everything unless you're soldering and using shrink wrap to seal your connections from the elements and corrosion. Also, buy a mini fuse set so that if you ground out a power wire and blow a fuse, you avoid a trip to the store
Otherwise, you may be able to find connector harnesses that turn 9003(H4) to separate 9005 and 9006 connectors.
Good luck!
Old Mar 3, 2009 | 07:28 PM
RasHondasDriver's Avatar
Do they make 02-03 lights? All I can find are 02-05, and 04-05 lights. Am I not looking hard enough?
Old Mar 3, 2009 | 08:04 PM
03K20A3Si's Avatar
We're talking about OEM headlight assemblies. Are you thinking projectors?
Old Mar 6, 2009 | 09:10 AM
Yup, whoops. sorry about that.
SELF MADE
Oct 29, 2011 08:07 AM
mister.wong
Nov 1, 2009 09:05 AM
thecruzs2007@yahoo.com
Sep 12, 2009 11:02 PM
evolvedAP1
Jul 10, 2006 09:18 AM
