2000 sedan w/f20b mount problems
Old Mar 3, 2009 | 10:12 AM
sohcdestruction's Avatar
Default 2000 sedan w/f20b mount problems
ok so i work for a shop here in CC tx and we got a 2000 accord sedan that came in with a f23 in it and he wanted the f20B in it so he bought the longblock online and brought it to us i pulled the f23 out and swapped the flywheel clutch etc.. over to the f20b and mated the tranny and got it ready to drop. but when i went to drop it in it seems the mounts do not line up the motor will not bolt in. no i thought this was because of the mount bracket (bolted to the f20b block) so i removed that and tried to bolt the bracket from the f23 there but it does not bolt up. what mounts do i need to use? i was under the impression this was a bolt in no problem swap but apparently not i also see i am going to have some wiring issues. sorry for the runon sentences and non capitiliztion and shitty punctuation im at the shop right now on a cell phone. kind of a pain in the ***. any help would be great guys
Old Mar 3, 2009 | 08:45 PM
Default Re: 2000 sedan w/f20b mount problems
Come on guys I need some help with these mounts here
Old Mar 3, 2009 | 08:46 PM
TheMuffinMan's Avatar
He knows where you live!
I would recommend you read the FAQ's as swapping an H is very similar.
Old Mar 4, 2009 | 10:03 AM
3uzfte's Avatar
I'm thinking that you need H series mounts. I wish I would be more of service.
Old Mar 4, 2009 | 09:53 PM
FunnyVictor86's Avatar
does the driver side bracket bolt up? i've heard the f20b motor mount bracket is supposed to solve the motor mount issue when doing the h22 swap on a 6th gen ...
Old Mar 4, 2009 | 10:04 PM
S.P.I.cc's Avatar
Good luck
Old Mar 13, 2009 | 11:02 AM
sicc22's Avatar
the f20B and h22 use the same mounts. i thought the SOHC F series used the same mounts as well. ive only worked with civics but the h2b mounts are the same for all H and F's. something else is wrong here. it might be operator head space.
EG type GTR
Jul 17, 2006 07:10 AM
JDM00SI
Dec 25, 2005 06:45 AM
rewerbcrx
15
Dec 24, 2005 07:50 PM
ludermark
Jan 23, 2005 11:28 AM
00WhiteEKy
Jun 22, 2003 08:54 AM
