b18a1 into 2000 si. Mount Brackets?
Old Dec 24, 2005 | 10:18 PM
JDM00SI's Avatar
Default b18a1 into 2000 si. Mount Brackets?
Hey,
So i have my b18a1 ona vtec head that im putting in my 2000 si.
Should i just use the mount brackets off my old b16 or any of the newer blocks or what in order to mount it? Is te only diffence the black mount bracket?
When i say mount bracket, i mean the black thing that connects from the block to engine mounts....
Thanks
JDM00SI's Avatar
quick bump
Old Dec 25, 2005 | 12:00 AM
j87w's Avatar
Default Re: (JDM00SI)
Do you mean the bracket that goes from the timing belt to the chassis? If so the EG/DC's have billet mounts there. They use a 3 bolt mount. The EK's have a 2 Bolt mount. If this is what your talking about then you need to remove the bracket off of your B16 and swap it out with the one on your LS. It'll bolt up fine then.
Old Dec 25, 2005 | 06:45 AM
JDM00SI's Avatar
Default Re: (j87w)
oh ok thanksf
str8up720
Sep 28, 2018 05:19 PM
the soL that could
Aug 21, 2011 07:08 AM
Adrian G. Aka JDMonkey
Oct 13, 2007 11:10 AM
EJCivJdM93
Feb 9, 2005 04:40 AM
S13 slide
Oct 14, 2002 10:07 PM
