00 civic si wont start!!! NO POWER
So i am new to the honda scene and decided to get me a 00 em1. Sick car but it had a small problem witht the throttle body. I got an itr intake manifold as well as the itr throttle body and decided to change it all, to my mistake, it was ALOT harder than i thought. this is the b16a by the way. So i got it all on, thought i got the fuel rail on, and decided to try and start her. She clicked, and died. I looked at the fuel rail and noticed i forgot the little rubber rings the fuel injectors go in. I put those in, put the fuel rail as well as the injectors back on, and tried to start her again. this time, there is no power. The headlights work, car beeps with the key in the ignition and all the interior lights work, just when i turn the ignition, no crank, radio doesnt work, nothing. I checked the battery fuse and changed it as well as the ignition fuse. I checked most of the fuses in both boxes. I checked all three grounds, the thermostat ground, battery ground and the one that goes from the valve cover to core support. STILL NOTHING. Im getting pretty anoyyed of this thing already lol. ANY HELP?
the first time i tried to start it, it all worked. everything turned on, it clicked once, like a broken fuse, then didnt do anything the second time i tried to start it. Now when i try to start it, it makes no noise, no crank, no nothing.
sounds like the starter, you might have disconnected the small starter ground by accident without noticing, causing the car not to start, check to see if the starter is all connected and see if it works.
rotory86
Dec 1, 2016 05:28 AM
OmgHondaSi
Sep 8, 2011 01:04 AM
