help instal gauges
aight i have a 91 civic hatch with a jdm d15b non vtec swap and i need help installing a oil pressure gauge and water temp gauge. i searched but im not having any luck with that ... idk where im suppossed to run the oil line or where the temp sensor is supp. to go
well what brand gauges are you using? did they NOT come with instructions?? does your factory temp gauge not work? you proly need to use an oil filter sandwich adapter for the oil press gauge sender unit to thread into. thats how i installed one in my b16
wait wait...so you trying to use an aftermarket oil press gauge with the factory sending unit?? uhhh this gauge you have should have come with a pressure sender sensor that you attch to the block like how i said. or a t fitting where the factory one goes. its a 1 wire sensor by the oil filter
Yea we have a fitting that should screw into the block, then a line goes to the gauge and the sensor screws in to the fitting.
I did not buy the gauge, so I don't know what all came with it. Just trying to figure it out now. Thanks for the info.
so you have a T fitting sounds like...you remove the oil press sensor from the block..attatch the T fitting...attach the oil press sender to the end, then the aftermarket
vtec69
Mar 12, 2003 10:31 PM
vtec69
Mar 12, 2003 05:54 PM
