Stripped head studs (block)
Old Mar 1, 2009 | 10:38 AM
The93egg's Avatar
Default Stripped head studs (block)
Ok so i messed up putting my head back on and the bolts would never get tight. I took them out and you can seriously thread off a piece of my block from the head stud.
I knew i needed a new block, but instead i tried putting them on again (this time i lubed them, i know hella dumb for not doing it in the first place) and they are all tight. I only stripped three. How bad would it be to run my motor now?
Old Mar 1, 2009 | 11:02 AM
trustdestruction's Avatar
Default Re: Stripped head studs (block)
so you're saying all the bolts seem to be in fine now?
if so, run it and see how your head gasket holds up. if it blows, you're ****ed.
oh and, you DID properly torque the bolts all in the correct order, right?
oh and btw you're not suppose to reuse OEM head studs.
dfJDM
16
Oct 22, 2012 12:28 PM
hYbRid_Eg6
Jan 26, 2012 10:00 PM
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
Peter Brady onlyonweekndz
Dec 4, 2007 10:22 AM
CTR-CRX
Mar 14, 2004 07:05 PM
