haveing problem with my clutch
are you losing fluid from pumping the clutch when the bleed bolt is tight?
if not, it's a bad clutch master cylinder
if so, it's either the master cylinder OR the slave cylinder
OR, none of these and you didn't bleed it enough or you forgot to tighten the bleed bolt.
