Question: 97 civic driving problems
Old Feb 28, 2009 | 09:52 AM
98tegLSvtec's Avatar
Default Question: 97 civic driving problems
hey guys i have a question conserning my 1997 honda civic dx 4-door.Its got the gay d16y7 but its my daily driver so i dont really care. My problem is that when im trying to hold a consistant speed going through town at 25-30mph it feels as tho its running outta gas...then when i push the gas down just a little bit more it kinda jerks back and forth then goes. if i hold the throtle wide open it stays at a consistent rate throught the rpm range. this problems got me stumped it also does it when the cars cold. its as though theres a flat spot
if anyone has come across this,or has any ideas as to how i could corect this that would be great, thanks
Old Feb 28, 2009 | 11:17 AM
UserX826's Avatar
Default Re: Question: 97 civic driving problems
how many miles on it?
Old Feb 28, 2009 | 12:13 PM
Former User's Avatar
Manual transmission? If so, what gear are you in when you have the problem?
Is the CEL ON? Have you inspected the plugs, cap, and rotor?
Old Mar 4, 2009 | 01:23 PM
245,000miles on the sheell
15,000 on the motor
Old Mar 4, 2009 | 01:26 PM
Yea it is a manual tranny... and it does it worse in gears 3-5
Yes the check engine light is on
the plugs are getting replaced this weekend and havent checked out the rotor
Old Mar 4, 2009 | 01:33 PM
Click here to learn how to pull the CEL code(s) at home.
Old Mar 4, 2009 | 01:34 PM
schwazel's Avatar
find out what code you have first.
Old Mar 4, 2009 | 01:47 PM
EL Vap133's Avatar
Check the plug wires and plugs, check dizzy, check throttle cable, check the throttle body for any build up, etc.
Old Mar 6, 2009 | 01:35 PM
Originally Posted by ronj@ht
click here to learn how to pull the cel code(s) at home.
thank you.!!!
Old Mar 11, 2009 | 05:54 PM
put plugs in and got the codes checked and it came up IAT (intake air temp) sensor,and secondary o2 sensor, so i checked the iat sensor and noticed that one of the two wires was infact pulled out so i re-soldered it and plug in the o2 sensor and it runs 20x better but still does it slightly every here and again.....
Old Mar 11, 2009 | 06:34 PM
Kista20's Avatar
full tune up and replace the fuel filter if you haven't done so already also be good to clean the throttle body as well, good luck
iiPancho
Dec 9, 2013 03:43 AM
skier
May 26, 2013 05:14 PM
mds_16
Apr 28, 2011 04:14 AM
Honda_Accord
Honda Civic (2006 - 2015)
Oct 1, 2010 04:33 AM
RickyBizee
Nov 16, 2006 07:17 PM
