Over heating problem eg civic t4 turbo top mount
Old Feb 27, 2009 | 01:50 PM
araz's Avatar
Default Over heating problem eg civic t4 turbo top mount
can any one tell me how to fix my car i have a overheating problem the car over heats after 20 min please helpp
araz's Avatar
Default Re: Over heating problem eg civic t4 turbo top mount
Help meeeee
Old Feb 27, 2009 | 03:12 PM
delsolnewkid's Avatar
things to check, in order of easyness,
-plenty of coolant? radiator full?
-replace your thermostat?
-check your timing?
-change your headgasket?
Old Feb 27, 2009 | 04:41 PM
hondaracing84's Avatar
Two more things you should check when making sure its full of coolant. Make sure there is no air in the system. On older motors there is a bleeder valve on the coolant outlet on the cyclinder head for the upper radiator hose. Just make sure the air bleeds out.
The next thing, look at your water pump. There are bleed holes there. If the pump is no good fluid will be leaking out. Basically make sure your water pump is in good working condition.
Also, Im assuming you have a radiator fan right? The picture shows the turbo right next to the radiator. Im guessing the fan is small and at the bottom since the turbo is at the top. Your fan might not be efficient enough. Does it over heat while driving or mostly sitting?
Old Feb 28, 2009 | 11:24 AM
araz's Avatar
There is just too much heat after 30 min the temp rises up really fast when the car get hotter i just did this setup i duno what to do about the heat there is just no space to put a bigger fan
Old Feb 28, 2009 | 11:28 AM
EK2.0's Avatar
Another thing to check that is often overlooked is to pressure test your radiator cap, if it doesn't open at the OEM PSI rating it will raise the boiling point of your coolant so the temp will go way up. just another thing to think of.
Does it overheat when your driving around or more when your sitting/idling?
Old Feb 28, 2009 | 11:31 AM
EK2.0's Avatar
Another thing you might think of doing is using a pusher fan instead of a puller! mount the fan infront of the radiator where you have lots of room for a bigger fan.
Old Feb 28, 2009 | 12:41 PM
araz's Avatar
yea there is no room to mount to the front of the radiator.the car start over heating no matter what if i leave it on for a long time or drive it.
Old Feb 28, 2009 | 01:04 PM
turbo sol's Avatar
did this just start with the turbo install?
i had del sol that was overheating, bc when I installed the turbo I took out a panel where the A/c condensor would be. (next to the radiator) this allowed the air to go around the radiator and cause it to overheat.
I just put a piece of card board in the space next to the radiator and it worked much better.
Old Feb 28, 2009 | 01:10 PM
araz's Avatar
the fan is a pussher and a puller
Old Feb 28, 2009 | 01:32 PM
EK2.0's Avatar
Well IDk what your set-up looks like in front of your radiator but i know plenty of people who run the fan in front of the Rad and make it fit. now IDK if that is really your problem but if it is thats about the only way to fix it if you can't fit the fan behind the Rad. how big is your radiator now? diameter wise I mean?
freshgear
Jul 19, 2009 01:48 PM
minime-dom
Jul 9, 2009 09:37 PM
hmtcrxsir
14
Aug 10, 2006 04:12 AM
mR. Vash
Aug 20, 2004 04:46 PM
bigslimdog
Aug 10, 2004 03:37 PM
