Gsr cluster in EG
Old Feb 26, 2009 | 04:39 PM
deemy72's Avatar
Default Gsr cluster in EG
I put a gsr cluster in my eg coupe and all the wiring is done but for some reason it doesnt light up my boy double checked all the wiring and it still doesnt light up
when i had my ex cluster it sometimes it lighted up and sometimes it didnt.
what might be the problem?
Old Feb 26, 2009 | 07:13 PM
performs's Avatar
Default Re: Gsr cluster in EG
you know im sort of having this same problem.. sept i got my stock gauge cluster in my 92 si... the light comes on stays on and some times it shuts off.. when you get an answer on the light thing or know the answer to why the light is on some times and some times not.. let me know man cause its irritating and i cant figure out why the hell it does that. but hope you find your answer sorry im not much help.
Old Feb 27, 2009 | 04:21 AM
deemy72's Avatar
need help
checked all the fuses there all good under the dash and hood what can be the problem? harness?
Old Feb 27, 2009 | 04:53 AM
swells's Avatar
Have you tried cleaning the plugs from the harness to the cluster? Sometimes the cluster may have dirt and grind in it.....I had that problem a long time ago and I tried that and didnt have any problems after.......*hoping this will work*
Old Feb 27, 2009 | 10:44 AM
deemy72's Avatar
what do you mean clean the plugs? cause my ex cluster didnt light up either
Old Feb 27, 2009 | 12:18 PM
T3KNiQe's Avatar
This might sound dumb, but are you sure the bulbs are in there?
Old Feb 27, 2009 | 01:40 PM
deemy72's Avatar
Icon6 Re: Gsr cluster in EG
lol yeah they are I double check that already
Old Feb 27, 2009 | 01:52 PM
jimmytmach's Avatar
It may be a fuse. Check all your fuses and the dimmer switch.
Old Feb 27, 2009 | 05:05 PM
deemy72's Avatar
I did check the fuses and the dimmer is all the way up and it still not lighting up!
Old Feb 27, 2009 | 05:22 PM
T3KNiQe's Avatar
So you have bulbs, wired correctly, and fuses are good....and the gauge cluster is actually working just not lighting up correct?
Old Feb 27, 2009 | 05:29 PM
deemy72's Avatar
wait I moved my dimmer up and just realized nothing changed I also realized my lights 4 my a/c dont light up either
Old Feb 27, 2009 | 06:43 PM
ozprelude's Avatar
check the the electrical modulator circuit box i think thats what its called. i Had the same problem in my 01 prelude no lights for my gauge or climate control worked here there was a radio wire for my cd player grounded out and melted this module box. after replacing it everything works.
Old Feb 27, 2009 | 07:19 PM
trustdestruction's Avatar
Sounds like a faulty dimmer switch, since it was already having problems before the cluster swap.
Old Feb 27, 2009 | 07:22 PM
franklinhid's Avatar
sounds like the dimmer switch.
Old Feb 28, 2009 | 10:26 AM
deemy72's Avatar
I could just pop the dimmer switch out with screwdriver right? and then what do I check?
and where is the electrical modulator located?
Old Feb 28, 2009 | 01:53 PM
deemy72's Avatar
Old Feb 28, 2009 | 05:02 PM
pop it out carefully with a flathead screwdriver
test it like this:
http://hondacivicforum.com/forum/sho...15&postcount=3
Old Feb 28, 2009 | 06:56 PM
deemy72's Avatar
test it like this:
thanks ima do this tomorrow, its to dark out lol
Old Mar 6, 2009 | 06:23 AM
deemy72's Avatar
problem solved it was the dimmer
weekendboost
Apr 8, 2013 08:38 PM
JaayDeeEmm
Dec 9, 2012 10:47 AM
ShookOne
Feb 18, 2010 05:19 PM
deemy72
Feb 26, 2009 07:30 PM
sing
Mar 6, 2007 06:08 PM
