need advice civic swap
ive got a 93 civic ex and i just bought a b18b complete with ecu and harness.
i need to know what i need to do to get this swapped. I have done some reserch and i keep getting different answers. can i get an odb2 to odb1 adapter? i was also told to use my d series harness. please someone help, anyone
yeah you either change the dizzy or get a conversion kit, make sure you got a rear mount off of a 99-00 si or crv. As for the alternator, check the plug if it's the same as your obd1 plug, it should work.
Before this thread gets out of hand, there are a couple ways of doing this.
If you get the full engine harness from a USDM Integra, everything will be plug and play with the '97 parts. The JDM harness is different, because the ECU is on the other side of the car, as well as the plugs leading to it.
If you want to use your stock OBD1 harness, then the OBD2 distributor, alternator and injectors all have different plugs.
Read this thread for more info (6th post down):
https://honda-tech.com/forums/hybrid-engine-swaps-18/1-8-dohc-vtec-550976/
that link really didnt help me much. they were talking about b16. i have a 18b, i know that the harness will plug into my car and the ecu will plug in, but will it run,and will i have a perm check light? there has to be an adapter harness if it wont plug and play. i really need someone who has done this swap.
https://honda-tech.com/forums/showthread.php?t=550976
thanks for the info. the motor harness and ecu all came out of the same car. and yes it was usdm. so why do i need to get an odb1 ecu. i was told that the only difference was a cam sensor. And if i do have use a odb1 ecu wont i need an odb2 distributor? so does any one have a 93-95 ecu for me. i am more than willing to trade mine for a ob1.
I assume you mean OBD1 distributor, but your answer is no. OBD1 and OBD2 B and D-series distributors are electronically identical, literally the only difference is the actual plug(s) where the distributor connects to the engine harness, the sensors themselves are identical.
I assume you mean OBD1 distributor, but your answer is no. OBD1 and OBD2 B and D-series distributors are electronically identical, literally the only difference is the actual plug(s) where the distributor connects to the engine harness, the sensors themselves are identical.[/QUOTE]
if they are the same i can use my 97 harness and use my p28 ecu and it would be just fine. is that what im getting from this?
i understand now. i thank you for your help. i have a p75 but its odb2. is there any way to convert it? and ill ask again, does anyone have one to trade. i also have a p28 off of my d16z and a p06 i believe off of my d15 i am willing to part with one or two to get the right ecu
Usdmowns
Nov 30, 2007 04:01 PM
flatblk
Aug 9, 2005 09:30 AM
