Engine Painting WIthout Removing The engine
well, I can honestly say that this is probably not a good idea. Generally I'm all for doing crazy things that people say won't work, but there is going to be many places that you aren't going to be able to reach while the engine is in there. Not to mention that you won't be able to prepare the surface properly while it's in there. The only thing you MIGHT be able to get away with, although you're going to be able to tell that the engine wasn't taken out, would be to spray a black just all up in there, I donno.
Edit: Do what you wanna do man, 20 bucks says that you're not happy with it when you're done.
yea definitely by looking at it i all ready start sanding the bay down and i see i will have to remove the engine... will do it anyway thanks guys... i will remove the engine when i get my new motor mounts that will be a good idea
na... i got a sohc turbo thats all i need.... i start a wired tuck a little time ago i relocated the batery and the fuse box and also all the headlights lights has been reloacted and all the ac lines removed... so by removing the engine i will try to finish the wired tuck
Power Rev Racing
Mar 23, 2008 06:38 PM
SOHC_MShue
27
Aug 22, 2004 08:50 AM
