ls rods gsr pistons?
that has got to be the best site ive ever seen.. but still doesnt answer my question.. cuz i know i cant use gsr rods in my b18a1 ..or at least thats what the machine shop was saying..said they wouldnt fit.
When my Friend rebuilt his B18b, he used either GSR or Type R pistons and stock ls rods in an attempt to slightly increase the compression ratio.
I do not think he had any problems doing this, but was not there when he assembled it.
you can use any b-series piston, except for b20's. b16,b18's are all 81mm pistons, im not sure of b17's. but yes gsr pistons will raise compression, the pistons are rated at 10:1 (usdm) nd 10:5 or 10:6 for type r's (usdm). you don't have to shotpeen rods or get rod bolts but it is safer to go that route since you already have them out. my friend has had his completely stock bottom end and head ls/vtec for 2 years. 8200rpm all day long no problems.
IMO, if you're going to take your engine apart just to add pistons, i'd go ahead and buy another set of LS rods and crank and get those machined and what not to also put in...just doesn't make sense to me to do all that work just to add pistons and do nothing else
well i just had my crank micro polished, then came to find out that my piston walls were bored out... so there goes that whole idea... thinking of a resleeve..
The reason he didnt have a problem is because he was using an LS rod in an LS block. No change in rod length. The pistons, most B-series pistons are interchangeable. The pin height is all the same. so the only thing that really changes is the compression.
averyvm
Apr 13, 2007 09:08 PM
