got one qestion about taking pistons from different b series.
I got some GSR piston and rods (p72) that I am trying to put into a B18A1. is it better to use GSR pistons and rods. or should I use the GSR pistons on the LS rods.
rofl wow. ls has a longer stroke than a gsr, you can not use gsr rods. if you are going turbo, which is what your other thread says, use the stock ls pistons and rods. raising compression on a boosted motor is just asking for detonation.
on a tangent, this motor is going to blow up. the end. looking at your other thread, those cylinder walls look horrendous, and a novice building a motor by himself is a recipe for disaster.
Re: (doood)
I got these GSR pistons for free and I thought that all b series parts are interchangable.
also I didnt think that a 9.7 to 1 comp ration would be too high to boosttt
ok, but gsr pistons are not 9.7-1 c/r
depending on whether they are usdm or jdm its going to be over 10 either way. hope you have a good tuner..
and to the first part of you post, b series are interchangeable as long as you know what goes with what, and it seems you do not.
Re: (averyvm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averyvm »</TD></TR><TR><TD CLASS="quote">And another thing my motor is not going to blow up.
Ill make sure to post up all my oil changes just for you
rofl i would be more worried about they cylinder wall cracking than your oil have bits of metal in it. which it will.
i understand this, i have made 300whp+ in my last gsr, but this kid is saying numbers like he knows that is exactly what his c/r is or will be. he has no clue what he is talking about. a b18a1 has a c/r of like 9.2 and gsr has a c/r of 10+. 9.7 is a number he is fabricating in his mind if he has stock pistons, which from his posts he does.
turbodelsolb16a2
02-07-2010 07:57 AM
