94 Teg LS NO HEAT
Why can't we search forums?
I've been having problems with the heat in my 94 Teg LS. I left my boys house and the fan wouldn't kick on, left it sit for a bit and it kicked on. Now the fan will not turn on AT ALL. I'm thinking the heater blower motor?
Any suggestions?
Any suggestions?
Check the fuse first. If that's fine I'd check the connections going to the fan with a voltmeter and make sure it's getting power. If it is, then your motor might be bad. Try knocking on the motor or hitting it (not too hard!) lightly with a hammer, sometimes those things just get dead spots in them.
I ended up replacing the heater blower motor. That was the problem, I took the motor out and hooked it up to a 12v source and it spun once around and then seased. Thanks man.
I am having the exact same problem.....can you elaborate on how you changed the blower and where you got the new one. How hard was it... how much did it cost? Thanks for the help.
unclejemima
Jul 19, 2004 04:32 PM
