94' civic Fan blower motor
ok, my fan seems like it's not comming on that strong, maybe due to a old blower motor, so i was thinking of replacing the blower motor but i want to know if it'll make the fan blow alot harder, cause man it takes a while for me to feel the AC when it's hot!
Also do i have to bleed out the freeon just to replace the blower motor fan? lmk thanks
Re: 94' civic Fan blower motor
If the fan does not blow hard, then remove the three screws that hold in the blower motor below the glove box. The blower motor will then drop down and can be removed after unplugging the connector. Who knows, the blower may just be clogged with leaves and debris.
I've had to change my blower twice. I has nothing to do with your ac/heat system apart from blowing the cooled/heated air out of it.
Do check to see if has anything clogging or otherwise restricting the fan from turning. You'll likely hear any debris if you listen closely.
stinkbox
10
09-15-2011 02:02 PM
