intake dont fit???
Old Aug 10, 2002 | 10:01 AM
dose's Avatar
Default intake dont fit???
i got a 92 civic w/ a b18c1 i got an aem cai and it dont quite fit
Old Aug 10, 2002 | 12:15 PM
Kamin's Avatar
Default Re: intake dont fit??? (dose)
did you get the CAI for the civic?
thats the problem
you need one for a gsr.
Old Aug 11, 2002 | 08:52 AM
dose's Avatar
Default Re: intake dont fit??? (KAMiN)
no i got it for a 94 gsr
Old Aug 26, 2002 | 03:56 PM
hybrider's Avatar
slide the aem peice in between the radiator and the tranny, only way it will fit
Old Aug 26, 2002 | 07:00 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: intake dont fit??? (hybrider93)
Modifications must be made to the pipe in order to make it fit properly. Try a search on it cuz im not too sure on how to do it.. i think you have to take 2 inches off it or something weird like that. Try a search, good luck!
Old Aug 26, 2002 | 07:04 PM
jdmhatch's Avatar
You have to cut that bracket it has. I also had to take out a nut that was holding the AC lines so that i could move them a little. Other than that just have to use some elbow grease to get it in there. Not too hard. Let us know how it goes
Old Aug 26, 2002 | 09:59 PM
rolow's Avatar
Default Re: intake dont fit??? (jdmhatch)
If you have a/c it is not bolt in. One way is to cut the pipe and put in a AEM bypass
That should help you get the pip where in needs to go. I just took out the A/C
Hwy100IVTEC
Feb 12, 2007 07:05 PM
DC5 05 type S
Oct 17, 2004 11:01 PM
Philip
10
Jun 3, 2003 10:32 PM
Civichatch972
19
Feb 2, 2003 07:15 PM
twinkie
Sep 22, 2002 10:31 PM
