hondata question!
Old Aug 10, 2002 | 08:10 AM
TurboDC4's Avatar
Default hondata question!
Are you able to run higher compression on pump gas with a hondata instead of a reg ecu! Looking to run ctr pistons in an ls/vtec.
Old Aug 11, 2002 | 12:36 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: hondata question! (SpoonDC4)
nope
Old Aug 11, 2002 | 01:26 AM
Dutchie's Avatar
Default Re: hondata question! (Mista Bone)
Why not? What would you use to tune it Bone?
Old Aug 11, 2002 | 07:49 AM
TurboDC4's Avatar
Default Re: hondata question! (Dutchie)
Do you have anything to support this "nope" , or where you just saying nope?
Old Aug 11, 2002 | 08:15 AM
Quick 200k Mile Motor's Avatar
what octane is available in your area?
Old Aug 11, 2002 | 08:17 AM
TurboDC4's Avatar
Default Re: hondata question! (Quick 200k Mile Motor)
93 is the highest.
Old Aug 11, 2002 | 09:28 AM
Im afraid ctr pistns & vtec head might yield more than 11.6:1 (which is the recommended for drivability on street with 93 oct).
The temp increase while youre on the street will suck. Even with 12.0:1 comp & 94 octane, you can get detonation down the road, which means you might need to run less aggressive timing curves. *Datalogging option
Old Aug 11, 2002 | 11:27 AM
hmonglonertim's Avatar
I've seen 110 octane at a gastation in clearwater for about $5 a gallon.
Old Aug 12, 2002 | 04:13 AM
Mista Bone's Avatar
D Tranny Guru
nope because of tuning. Hondata just makes it easier...........
Compression/Octane/Fuel/Ignition timing, all part of the formula. Go outside of the formula/tuning and you go from a Otto cycle engine to a Diesel engine.
Old carbed V8 statement..........
Holley for WOT, Carter for part throttle.
92integraVTECgsr
Dec 25, 2005 08:32 PM
QuarterMileMaster
Nov 18, 2004 12:15 PM
Revhard92si
Jun 4, 2004 10:48 AM
omega11855
20
Oct 29, 2003 08:58 PM
Austin
Jul 10, 2001 08:28 AM
