Tune?
Old Feb 22, 2009 | 11:06 AM
PhrequenC's Avatar
Default Tune?
Can anyone help me with a hondata s300 tune?
i need to run it on a bone stock b18b1 stock injectors for about 2 weeks until my injectors come in!
its a garrett .50 trim t3t4. i just dont want anything to blow up cause this is my DD.
if you can help me out please point me in the right direction
Old Feb 22, 2009 | 11:18 AM
Ls_dx's Avatar
Default Re: Tune?
Well for starters, DONT GET INTO BOOST at all with stock injectors
Old Feb 22, 2009 | 01:18 PM
xenocron's Avatar
Default Re: Tune?
Just upload the Stock B18b map, put the boost cut at 3 psi and enable Closed Loop and you should be fine.
Old Feb 22, 2009 | 01:20 PM
Ls_dx's Avatar
Default Re: Tune?
there ya go... xenocron is the ****
Old Feb 22, 2009 | 05:54 PM
PhrequenC's Avatar
Default Re: Tune?
im about to order a set of rc 440s saturated. where should i go from there?
PhrequenC's Avatar
Default Re: Tune?
i dont have the boost option on my s300
Old Feb 22, 2009 | 10:05 PM
mtber's Avatar
Default Re: Tune?
The boost option you are referring to is the "boost control" feature which allows you to use the ecu as a boost control device with an external solenoid.
Concerning your situation, contact the dealer you purchased your s300 system from to see if they can provide you with a base calibration from a vehicle they have tuned.
Djbigwill
Jul 12, 2013 04:44 AM
AJxr
Feb 5, 2006 09:03 PM
project civic
Sep 5, 2005 04:07 PM
zbower7
Jun 12, 2004 09:12 PM
turbocivic22
May 11, 2003 04:39 PM
