B18c1 Head Gasket help ???
Old Feb 21, 2009 | 05:55 PM
KillaEj1's Avatar
Default B18c1 Head Gasket help ???
Ok so i have a Ej1 with a Gsr motor in it. Its all stock and even has the stock sohc exhaust on it as well. I just notice that the car has white smoke coming out of it. Seeing as it was the winter time when i bought the car i thought it was just because of the cold weather but now i found out that it is indeed shooting white smoke out of the exhaust and it does look like it is leaking oil from the head gasket on the front corner on the block close to the disturbitor. Does anyone know if this is my head gasket or not ?? and if so do you think the head is still good on it know that it is leaking coolant into the block causing it to have white smoke come out of the exhaust??? I just wanna make sure that it is the head gasket and not the piston rings. Also does anyone know to to do a headgasket change and how hard is it ? i know that timing might be my biggest problem so anyone with a write up would help me a lot.
Thanks
Old Feb 21, 2009 | 06:06 PM
stankcrx's Avatar
Default Re: B18c1 Head Gasket help ???
dude you cant have a sohc exhaust mani on a b18 dohc motor??? and check your oil if your head gasket is bad it will look like chokolate milk yuk....
Chaveli
Dec 11, 2009 04:07 PM
EfpormantypR
May 6, 2009 03:27 PM
mannydhanju
Feb 21, 2009 09:33 PM
lilromeoloc
Honda S2000
Jun 15, 2008 10:06 PM
CiViC I2aCeI2
Jan 20, 2006 06:49 PM
