Honda S2000 Honda S2000
motor blew ..... HELP?!!!
Old Jun 14, 2008 | 08:22 AM
lilromeoloc's Avatar
Default motor blew ..... HELP?!!!
alright .... this really sucks . I just put on a garret 30r and was dynoing my s2000 .... then it blew the dipstick out , white smoke came from all around the car and from behind the motor .... now im trying to figure out whether it was the piston rings or head gasket .... any help ?
Old Jun 14, 2008 | 09:14 AM
wilsel's Avatar
Default Re: motor blew ..... HELP?!!! (lilromeoloc)
Only advice I can give is to drain the oil, maybe even take the oil pan off to get a better look. Then go from there.
Old Jun 14, 2008 | 09:15 AM
alexisthemovie's Avatar
seems like it's something more serious...
Old Jun 14, 2008 | 09:18 AM
FSBxtreme's Avatar
head gasket blew causes white smoke = steam (from coolant entering into combustion chamber)
Old Jun 14, 2008 | 10:10 AM
Black S2K's Avatar
Default Re: (FSBxtreme)
^x2 but that might not be the only problem
Old Jun 14, 2008 | 03:07 PM
iam7head's Avatar
Default Re: (Black S2K)
wet/dry compression test
leakdown(if needed)
Old Jun 14, 2008 | 03:43 PM
AlphaKennyWun's Avatar
Default Re: (iam7head)
Remove head and inspect head gasket, sleeves, pistons and rings. Hopefully its just a head gasket. If so replace with a cometic head gasket and ARP head bolts. Tune again.
Old Jun 14, 2008 | 04:15 PM
95 integra's Avatar
Smoke all around the car? Maybe you blew off a coolant hose....I'd check that idea out. The dipstick thing sounds like cracked ringlands, but like everybody else said, you have a turbo car now, time to step it up and get use to fixing things on your own (ie, disassemble the bitch and figure it out for yourself) rather then posting rather vague facts and expecting somebody on the internet to tell you exactly whats wrong.
Old Jun 15, 2008 | 07:59 AM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSBxtreme &raquo;</TD></TR><TR><TD CLASS="quote">head gasket blew causes white smoke = steam (from coolant entering into combustion chamber)</TD></TR></TABLE>
i hate this whole "white smoke= steam" thing.
This is the ONLY way to tell the difference between oil smoke and coolant burning:
Oil smoke will LINGER. Coolant smoke will 'evaporate' or disappear, and coolant burning will have a sweetish smell to it.
If the dipstick blew, sounds to me like you cracked a ringland, blew a ring, and compressed air got into your crankcase.
Good luck dude.
Old Jun 15, 2008 | 10:06 PM
AnthraxVX's Avatar
Default Re: (chimmike)
ok, step one - do a compression test.
step 2 - leakdown
regardless you will have to take off the head = step 3
replace piston rings with the info from compression test.
possible valve damage - found through leakdown test
take off oil pan and windage tray - look at rods
in the beginning you should definitely look at oil as said above see if there are metal shavings or scraps. big chunks will most likely get stuck in the windage tray but use a magnet to get chunks out of the oil that drains or strain it.
minimal damage is head gasket -
but it could be a lot worse especially since ur pcv must not have been working since it launched ur dipstick or if there was so much pressure ur pcv couldnt release it in time.
good luck and pm me if u need any more info or any guy on here im sure. except u jk
shm91
Sep 1, 2013 03:56 AM
Chaveli
Dec 11, 2009 04:07 PM
zcmotor
29
Apr 18, 2008 10:20 AM
EnjoyTheRideDC2
May 19, 2007 08:58 AM
youngkow
Dec 27, 2003 12:18 PM
