88 Accord Alternator Removal HELL
Old Feb 20, 2009 | 03:37 PM
GavinJuice's Avatar
Default 88 Accord Alternator Removal HELL
Well it has come to this, i cannot for the life of me remove this alternator from the engine bay. The only way out is down and no way that i maneuver it can i drop it down without it hitting something. I removed the alternator mount and oil filter, they helped but no go. I thought maybe saggy motor mounts so i jacked up the engine from the oil pan a bit, didn't make a difference. I see two possibilities; one is to remove it out by the driver side wheel with the plastic splash guard removed, the other is to drop is straight down and remove the axel (which is in the way). Obviously i would avoid the latter if possible.
What have other people done with this, the book and any other resource i have seen is of NO help.
Thanks in advance ~Gavin
I've posted this in the classics also, i imagine there isn't much movement over there.
Old Feb 20, 2009 | 04:17 PM
Turbowa's Avatar
Default Re: 88 Accord Alternator Removal HELL
I hate to tell you but you have to remove that axle on the driver side to get the alternator out. As you can see it won't come out unless you do.
Old Feb 20, 2009 | 04:38 PM
GavinJuice's Avatar
man what a poor design, thanks for that bit of info. Everything i have read simply says to unhook and remove, which obviously isn't the case. Oh well, why couldn't the alternator have died at the same time i replaced that axle?! Lifes a beach!
Old Feb 20, 2009 | 04:41 PM
88LXi68's Avatar
Turbowa is correct, but if you have a fuel injected engine you may be able to remove it by pulling it out from the top.
Old Feb 20, 2009 | 07:27 PM
dtapia's Avatar
yup remove the axle it will almost fall out. i didnt know their was another way out the top.
Old Feb 21, 2009 | 07:49 AM
88LXi68's Avatar
Well I should have mentioned that you will have to remove some things like the stock air box, but nothing major. I can't remember what else would need to be removed as I swapped to a B-series almost 6years ago.
jimeby
Mar 8, 2020 09:07 AM
battini
Mar 6, 2009 02:16 PM
GavinJuice
Classic Hondas
Feb 21, 2009 04:37 AM
integral94
Apr 24, 2006 08:00 PM
Shft@9GSR
Nov 23, 2002 08:05 PM
