Blown Rings or head gasket?
Old Feb 19, 2009 | 06:48 PM
Unknown Racing's Avatar
Default Blown Rings or head gasket?
I have a stock jdm gsr on 10psi it made 300whp 190wtq and shortly after my tune I noticed white smoke coming from my valve cover breather. and sometimes my tailpipe. it seems to smoke at random. and my idle is very rough. I did a compression test this morning. the engine was hot and it was done at wide open throttle.
cylinder 1 - 210psi
cylinder 2 - 205psi
cylinder 3 - 150psi
Cylinder 4 - 120psi
The car does not overheat. it runs but with sputters and sometimes a stall The coolant levels and oil levels are fine. no sign of oil in the coolant or vice versa. Sounds like cylinder 3 and 4 have blown rings? I pourd a little bit of oil in the cylinder 3 and the compression went up to 190 psi
Either way im gonna have to tear down the engine
the car ran fine and then I filled up my tank and then this happend. Im wondering if I got bad gas or something
AFR are in the high 11's and Total Timing is 18 Degrees before the incident
Old Feb 19, 2009 | 06:57 PM
non-VTEC's Avatar
Default Re: Blown Rings or head gasket?
probably cracked piston ring lands.
Old Feb 19, 2009 | 06:59 PM
slowturbocx's Avatar
ringland
Old Feb 19, 2009 | 07:04 PM
tegman23's Avatar
ringland X3
Old Feb 19, 2009 | 07:05 PM
My afr are insanely lean now after it started smoking
Old Feb 19, 2009 | 07:14 PM
EGhatch87's Avatar
ringlands
Old Feb 19, 2009 | 07:25 PM
SovXietday's Avatar
Originally Posted by Unknown Racing
My afr are insanely lean now also
Uhhh did you happen to put a new fuelpump in when you put the turbo setup on? If not, that's why you blew your ringlands.
Old Feb 19, 2009 | 08:17 PM
Walbro 255 my Afr are lean after the smoking started not before
Old Feb 19, 2009 | 08:30 PM
TheoneTheycallVille's Avatar
ringland
Old Feb 19, 2009 | 08:48 PM
yeah I was 90% sure its the ringlands just wanted to know what my fellow honda tech members thought
Old Feb 19, 2009 | 09:17 PM
ironcheftony's Avatar
Ringlands ftl
Old Feb 19, 2009 | 09:40 PM
I guess its build time. is it really bad to drive on the car still?
Old Feb 19, 2009 | 09:43 PM
Scott_Tucker's Avatar
You could get a false reading from your AFR meter since the engine is misfiring so bad. If the cylinder never fires then all the oxygen that was supposed to be used to burn the fuel instead goes past the A/F Ratio sensor and tricks it into thinking the engine is lean.
Old Feb 19, 2009 | 09:46 PM
With those compression readings I would say yes, it is really bad to drive it. If a chunk of piston or something was about to break off it could damage the cylinder head.
Old Feb 19, 2009 | 10:23 PM
good to know thanks
Old Feb 20, 2009 | 12:15 AM
ACTION JACTION's Avatar
Ouch! Hopefully you get her fixed soon. Good luck with the build, be sure to post up some pics :D
umskittles
13
Aug 3, 2011 06:40 PM
801ef
May 19, 2008 09:03 AM
k_lude
Aug 16, 2006 05:09 PM
SiRkid
Jan 4, 2005 06:34 PM
Sport_Injected
Aug 14, 2004 01:45 PM
